View Full Version : KLX 250S
- I hate my MT21 front tire.
- parts for sale
- FMF Powercore 4 - Quiet Insert
- What the $%#@ front sprocket?!?
- How to align your forks after a crash?
- Best Place to Buy a FMF Q4
- Replacing clutch. Tips?
- Web Cams 101 instalation
- 351 and Pumper installed!!
- 98 klx300 cylinder on 06 klx250s
- Magnetic drain plug
- Bigger Tank...?
- Easiest bike to stall?
- klx 250s 351 big bore stock jetting
- 2014 No new updates
- Help with KX250 forks
- Will a 2007 speedo gear assy fit on a 2006?
- Hardest thing to clean off the KLXs
- Replaced my idle mix screw - Much Better
- TM36-68 Broken Pilot Fuel Screw
- KLX 250 Plastics
- IMS tank install help
- Husky TE 250
- Best mods for the road
- Too hot
- Skidplate Woes
- Ebay Find of the day/Exhaust compatibility
- JUST WENT DOWN ON THE KLX ! Picture of Damage
- Stock Cylinders
- Hot start issues?
- I'm cursed....
- 93 Octane klx250sf
- New NorCal KLX rider
- Rear tire upgrade ? Klx250SF
- TUFF LITES (blinkers) from Extreme Dual Sport
- When to repack
- KLX250 stock exhaust mod
- Engineering Project
- Webcam install basics?
- July BOTM
- Cheapest price for kick start kit
- Harley Dual Sport Motorcycle
- Stainless Brake Line Routing
- Help jetting 8000+ elevation
- Tired of the Wimpy Stock Horn?
- PM racks
- 09 KLX250S throttle tube
- 6-22 Dual sport ride
- "Trail" Sprocket Advice
- Coolant Overflow Tank Hose Clogged?
- Ran into some difficulty
- New member stopping by...
- Saddlebags and the Nomadic Rack
- Passenger pegs wanted!!
- Another Jetting question
- Master link for stock chain, 2007
- What am I doing wrong?
- Looking for a Locking gas cap for an IMS tank
- 2009-2013 klx250 ims gas tank brand new make offer
- My ride up Angeles Crest.
- Stock carb and 330 upgrade Q
- Colorado - Taylor Lake Advice
- Emperor Racing (aka Scorpion) Rad Guards
- Scratched up plastics
- Buying a used klx250
- Carb and bike slow to warm up
- I need some help! Broken Bolt!
- Bike cover for KLX250s
- 09 KLX 250s: Second Owner, a few questions and looking for advice.
- Good news and I'm ready for the told you so'
- Oil filter
- My First Bike
- A little water crossing video from yesteday.. KLX351 and KTM 200
- Another ticking question
- Power gains thru advancing initial timing?
- HOW TO: Fork oil change
- Shift star replacement question
- My friend made me hate my KLX 351
- Just picked up this clean 06 klx250
- Flat Spot at 4K-5K
- Kiwi klx250h2
- knobby cutting.
- 07 KLX250S Stuttering/Jerking?
- What a difference !!!!!
- So if I move back to California...
- WTF is up with the "Honda is changing the game with 8 great bikes under 8k" videos
- New Klx owner needing help
- 351 and Mikuni Carb
- radiator shrouds ?
- Hello from Croatia!
- Options for hitch mount carrier
- Valve shim diameter
- Parts
- This is Same Parts ?
- Ignition cover plug/inspection plug
- Latest mods & add ons.
- Starter Motor
- KLX high/lo beam separate elements or
- 2007 KLX250S - 360 Miles - Good Deal?
- New tubes
- Ground Wire Mod
- New to the Forum - Just Bought 2010 KLX250SF Blue ( I have ?s lol)
- The End - Moving onto pastures new
- Delta Full Exhaust F/S
- Help me find an acerbis tecnik fender!!!!
- Fork Tool--thinairflyer
- Shift/brake levers and rear sets?
- How many miles on a KLX250S is too many?
- Radiator Shrouds
- New gear just arrived
- Who's Running Front Rim Locks?
- Vance & Hines Performance getting spanked by California
- 38 tooth rear sprocket
- More Power
- I've got a dirty dirty little.....bike
- Finally!
- Radiator cooling fan question
- amber reflector
- I ordered a iM2100 Pelican Case today
- New Member.
- More ticky-tacky, not cam chain
- Tires for desert
- Don't underestimate the mighty KLX.
- A little Story: My First Off-Road Adventure (not what I expected)
- Speed Calculator
- KLX250 missing & weird sound (after wheelies)
- How to contact Bill Blue? Need some spare gaskets
- 351 kit f/s
- Weight to be shed?
- Where to find valves and pistons
- Front end singing/whistle
- Will this exhaust fit?
- Trailtech vapor
- Ticky tacky KLX
- interesting day on the freeway
- KLX250S Front Mudguard/Fender Question
- 09 klx250s Rear shock info needed
- klx 250s B and B aux. gas tank
- What's differant between D-Trucker and KLX 250s?
- Drilling the slide
- Engine Cutting out....PLEASE HELP
- 351 install CNY
- Gas Overflow Tank
- good place for parts?
- Officially have the worst luck
- Clutch lever dust guard getting caught
- 09+ Turn Signal Bulb
- 06 Valve adjustment question/problems
- Which Jet Kit? Honestly, I did a search first...
- Idle mix screw thread pitch/diameter?
- New club grounds video
- Road tires s or sf rims
- Thinking about getting a KLX250S
- Zeta guard mirrors
- Parts in Lousiana
- New tires arrive in time for the weekend!
- help needed
- Another Newbie Question
- Did they give me the wrong tube?
- Aftermarket Plastics?
- WTT Big Gun Evo R for FMF Q4
- RCMP Rider Training Drills
- Sound about right?
- Rear Sprocket Question
- Air Fuel Mixture Screw for $10
- Home style Axle sliders
- Low speed crash, fork alignment
- 2010 klx250s kickstart?
- Looking for 06-07 flywheel
- Racetech Question
- How was the suspension travel shortened on the '09 model?
- Removal of my leaky, from day one, coolant overflow bottle?
- Another Boring Utah Trip
- Poor Man's Integrated Handguard Mirrors
- New front tire
- Little Kawi comes through!
- How many KM do you normally wait to check valve's and such?
- Weird rattling noise
- Shop manual info
- Trying a new muffler
- A word from the wise......
- Barkbusters Handguard Instalation probleme cause of stock handlebar
- Carb Icing?
- KLX250sf Turbo
- Selling my klx
- KLX250 EFI - larger IMS tank - awaiting stock
- Surging and related issues
- '07 KLX250S side cover interchange?
- About to begin the madness
- KLX 250s Wheels
- Looking for plastics!!
- '09 KLX250s fork teardown pics
- REVIEW: Trail Tech Tach
- Any Motorcycle Mechanics in Detroit Michigan Area?
- Need a cheaper bike than the KLX - Thoughts / advice welcome
- Gpr exhaust review
- 2009 and up KLX250SF rear spoke diameter?
- Klx 250 Connecting Rod Problem
- Oil Filter O-Ring Help!
- Stalls under hard braking at idle
- xt225
- Ride report from yesterday
- And the questions go on...
- Power point......cell charger....cig lighter kit.etc.
- Brighter Headlamp Bulb
- New Owner
- Another Little Adventure
- tough to get into 1st gear when hot
- more handlebar help
- Wanted a Yamaha XT but now I own a KLX 250s
- New fuel lines
- Newbie Question--removing exhaust/muffler
- New wheels help uk
- The epic saga of Kawibungle
- Just bought a 07 KLX250s Need wheels
- Ok I have a question
- Bike Wander
- 250 vs 450 weight
- Rear shock was soft, then it wasn't...
- KLX250sf Concerns
- Advice for what exhaust,,?
- More on the top end?
- tm 36-68 help
- Getting The Feel for It
- $78 in gas over the last 6-months
- I am a stupid numpty and may have killed the KLX, need advice please.
- temporary battery
- KLX250s for parts
- Tires
- dont have time for my 2012 klx250s
- Powerbomb heat guard?
- Red or Black rims??
- My new neighbor is a Kawasaki fan
- Backfire? when letting off throttle at high rpm
- Can anyone tell me...
- Kudos to Jets R Us
- yeah yeah I know more mod talk...
- S vs SF forks
- Polished Ports and Webcams.
- Bike stalls when clutch engages
- A short ride report
- Fuel Lines and Smog Plugs
- After five fantastic years with the Green Monster, we part ways ...
- Kouba extended fuel mixture screw?
- big bore is in
- Oil drain plug width
- KLX 250 2011 Part Out
- 2007 KLX250S For Sale
- New here and some questions
