View Full Version : KLX 250S
- The Hurt Locker.
- Lowering Links For Sale - Removed from 2007 KLX250S
- New Video - Soup & Salad
- 06/07 Owners: license plate options?
- Buying a blown KLX250S
- Upgrade cost on new KLX250
- Custom seat
- KLX300R in a KLX250 frame?
- Carb vs f.i.
- Pre-09 wheels on newer models?
- EFI MCM Lidless slip-on tuning
- 2018+ Clutch switch mod
- Dinged crankcase cover replace and protect!?
- help posting signature on this forum
- Trying to muffle intake sound
- Wiring a USB
- 2004-2006 KLX250 tank upgrade
- What is the coolant flow direction on the KLX250/300?
- recomendation for cheap lowering links
- 2009 smog removal
- Road wheels/ Rear Tire width for S model
- KLX351 installed + overheating
- Low charging voltage
- How do you lighten the bike?
- Speedometer display problem
- Look What Came in the Mail Today
- 2014 KLX 250S Compatible Rear Shocks
- 06 KLX250S Suspension Link Question
- Replacement foot pegs
- Buying Used KLX250S
- Now a rod kit for the KLX250/300
- 2008 KLX250S starting problem?
- KLX351 + Barker Exhaust + EJK + MCM
- 2009 klx250sf
- Tires for Dirt
- KLX250SF Knobby Front
- Noob question: carb not draining through drain plug
- Short replacement clutch/brake handles for 2006 KLX250S
- 2009 upgrades started
- About to rebuild my front forks, what weight oil should I go with?
- 2009 KLX 250 s not starting, but electric start works fine...
- Zeta Offset Handlebar Risers
- Is cam chain adjusted correctly? Sound file
- So what am I doing incorrectly? Speed sensor issue
- Has my bike been lowered?
- 1996 klx 250 radiator shrouds
- Manual cam tensioner install
- Not bad but rather unfortunate news!
- double post. delete please
- What is wrong with my kickstand
- Recommendations for cheap chinese head pipe
- Do pre 2009 klx250 exhausts fit on 2009 and up?
- The old WR vs DRZ vs KLX complex, I hope I have a solution
- Painting the rims
- Info Thread: KLX250S EFI with Big Bore (351, 330, 300, etc)
- Last weekends ride video.
- full muzzy exhaust jetting
- Surging at high RPM under load.
- Question about product sent to Canada and other countries
- So...I got the bike pretty much in time to go to lockdown
- advantages/disadvantages of quicker throttle tube
- So, about that kickstarter
- Jetting recommendation for Danmoto slip on exhaust
- Bike will no longer start in gear
- Is there slack for a bar riser?
- WTB: Stock height rear suspension links (dog bones)
- KLX for hard enduro?
- Replacement front forks
- stock gas tank cap vent
- klx 250 vs kx 250f motor difference`
- Route Planning
- ACR Removal or disable on BB 351 ?
- Supermoto wheels
- KX250F Monoshock in KLS250S - Possible?
- Looking for used Tachometer / Tachometer fix?
- New to the Forum... But My Videos Aren't
- Do I need a new clutch, or am I missing something?
- Noisy 13T sprocket
- KLX 300 piston installation
- What springs for 180lbs rider?
- Budget KLX steering damper / stabilizer?
- Need help with 2019 throttle assy
- 351 kit and MCM mod
- Cams worn out
- Help with unknown wire please
- Rear disk rotor - 240mm?
- Damaged Valve Lifter
- Phone Charger/Power Options
- How often you change your fuel line n filter
- Newbie
- D-Tracker 250 engine sound
- Finish durability of Blacked out KLX
- KLX250S Parts list
- Starting free mods-what fuel adjust screws are avail?
- Another KLX 300 cold start problem thread
- 06 klx250 I want to put on a q4 exhaust
- Rear suspension dogbone link length
- KLX 250 Starter Motor replacement options?
- Looking to buy a KLX
- 2011 Fork MOD
- New Owner-thanks to Klxster for advice
- Kawasaki KLX250/300 vs LoncinYF300
- BB351 Bill Blue Update circa 2020
- Pulling in 6th
- First mod advice. *New*
- Carb spring I.D.
- 09 KLX250s suspension linkage rods
- Supermoto wheels
- Wouldn't it be nice and helpful if...
- Anyone do the secondary throttle plate removal mod?
- Ordered a new OEM coil and THIS NGK plug cap. Anyone else. Inexpensive alternative?
- New Thread! Could it be the COIL?!?!?!
- wanted stock oem exhaust for 2007 klx250s
- Carb woes.... is needle adjustable on '09 250s?
- Rear Sprocket
- How much do you think a KLX 250 S with a seized engine is worth?
- Wiring help! Aftermarket fender eliminator with turn signals.
- Klx250s UK Model efi - ejk settings plea for help
- Excessive Blow By?
- High flow
- KLX fails to charge the battery
- Recommended ejk settings
- 2018+ klx250 supermoto conversion
- Ejk
- Ride height.. Has my bike been lowered? Measurement please?
- headlight
- Motor swap question. 09 to 06-07 motor
- EJK and Pair Valve
- Ejk
- Thank You For the info
- Motor test
- Smog and 'pairing valve'
- MCM check
- Cam bolt specs
- 2018 KLX 250 Rim/Tube Tire Question
- Fitted Delkevic now got fast tick over
- Snorkel mod
- Chinese powerbomb
- 2020 klx250
- Still no plastic skids?
- 2011 Klx250s, need manual cam chain tensioner Australia.
- 1994 klx250 output shaft
- 2011 Klx250s Broken Dashboard, Trailtech questions.
- 2013 Klx250s order of performance mods questions
- Clutch Cable length
- 351 weakly cranking
- 2009 Plastic Vinyl Wrap
- What EJK settings are you using?
- How to tell if the bike it too lean?
- ICYMI- Scotts Stabilizer FS in Classifieds
- 2009 BB351 engine clack when rev hard from idle
- Is KLX300R top end compatible with KLX250?
- I have a dilemma with my KLX250
- Unsused connector, bad sounding exhaust questions.
- Dominator exhaust on 2018+?
- New EFI KLX250S performance testing needed.
- 2018 KLX 250 Suspension Settings
- What length clutch cable once bars are raised 2018 klx250 ?
- Rear Rack for KLX250S 2009 or newer.
- FMF Q4 muffler for carbed vs EFI bikes.
- Omg!!!
- Time for new front brake pads
- Fuel/air mix strategy for TAT ride?
- Aftermarket clutch kit?
- Stiff Clutch.
- Help to de-smog pair valve on a 2018 EFI??
- Sargent seat fs
- Anyone using a/m ECU on newer models?
- Bogging after a whoop
- 2013 running issue, possible jetting?
- 2007 Klx 250 forks won't rebound
- 2006 Oil Feed Banjo Bolt
- Sprocket combo
- Lowering links for 2019 klx250
- 2019 KLX 250 Soften Seat
- 2007 KLX 300 Carb Help
- KLX650 info
- Intend to sell to fund trials addiction
- Price check - 2009 KLX250s?
- SKF fork seal plastic spacer, needed??
- Chain and Sprocket cleaning
- Clogged fuel injector on a brand new KLX250
- Stiff Clutch.
- Jetting recommendations 1300 ft in Southern Oregon
- Hotter Thermostat
- Either everyone is riding or asleep...
- Engine failure. Options?
- Could the Krieger cam chain tensioner cause any big problem later?
- (Newbie) KLX250S-plastic kits changed/modified
- 12t front sprocket
- KACR catastrophic failure
- First Kawasaki-eighth motorcycle
- Can a 2009 klx 250 connecting rod be changed or do I have to buy full crank ??
- Can a 2007 klx 250 bottom end be used is a 2009 ?
- Are older model year exhausts compatible on new model years?
- 2018 KLX 250 Tuner question
- engine sound
- KLX 250 accessories
- Rear Break Caliper - Anti-rattle spring position
- 94 klx250r
- Help- not starting
- engine swap
- No o2 sensor on bike
- KLX250s bogging down above 7000 rpm
- To snorkel or not?
- KLX250S noise
- Is header wrap an issue?
- Old Issue, New Info. CVK Carb No Start. Choke / Enricher Jet Drilling
- Valve Adjustment Longevity
- Rear Sprocket
- 2019 KLX 250 exhaust options
- Fork Seal Driver Question
- Longer clutch lever
- BIGGER cheap footpegs
- Back brake intermittently not braking
- TM 33/34 Mikuni flat slide pumper carb
- Bleeder "nipple" size
- KLX Electrics
- Carb Help Needed
- Klx250sf supermoto wheels and tires
- Threaded hole on clutch perch
- KLX 250s clutch issues
- Performace Coil pack
- Klx250sf
- klx 300 exhaust
- Aluminum Panniers for a 2007???
- Please Confirm before I...
- I won`t run... HELP!!!
- Rear brakes
- Got me a TM-36 today
- Turn signal
- Lithium Battery for 2019 KLX 250
- KLX250 torque and power
- Dropped at low speeds. No front brakes now. 2018 KLX250
- Joined the kick start club today.
- Clutch basket rebuild?
- 2006 klx 250 carb replacement
- 2012 klx250s decides to leak fuel everywhere...
- 2009 No Start...
- Just a quick 300 miles
- klx300r
- 2018 klx250 running a bit rough after new exhaust
- weight savings exhaust kick start
- Where does this go?
- battery dead.
- Going Tubliss
- 299AHL vs throwing in a new OEM piston ?
- '07 overhaul, "katsumi" inspired
- IMS and Acerbis on 06: fitment issues
- fork conversion kit
