PDA
View Full Version : KLX 250S
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. changing clutch plates/springs
  2. Windscreen
  3. Oil filter
  4. FMF Q4 how to make as quiet as stock
  5. Milky substance on oil sight glass
  6. Rego question for Aussie KLX riders
  7. Water in Oil
  8. Like new 2009 KLX250S Red Plastic for your Green?
  9. Love
  10. More info on carb needed?
  11. Headlight guard, protection, shield
  12. Black rims on red 09
  13. Running a chain with two master links?
  14. Offer for Klx owners
  15. Stopping in to say hi.
  16. Encourage my bad behavior
  17. Drilled wrong size hole in starter jet
  18. KF members in Japan OK?
  19. Serive Manuals
  20. Does anyone have rear factory fender 09-11 forsale
  21. valve clearences tight or wide
  22. HELP! 2009 KLX oil pouring out of case & smoking from case!
  23. Acerbis tanks are in
  24. extended shift leaver
  25. Good to be back :D
  26. Dumb question
  27. Bill Blue pumper carb for sale
  28. Changing jets
  29. Does Anyone Still Sell a Kit to Stroke the klx ... and could I use my 351 Piston?
  30. Fork seals? Which are best? Leak proof?
  31. Pilot jet? 2006KLX 250S
  32. Just fork springs or valves too?
  33. Ok, now i'm pissed
  34. Difference in batteries??
  35. '09 KLX seat for sale
  36. Starter switch inconsistent
  37. Michigan cycle skills test
  38. shifter adjustment
  39. 09+ speedometer adjustment
  40. Front fender
  41. Exhaust hanger broke - MIG or TIG?
  42. Why is my klx such a whimp
  43. New pipe and Jet kit coming Questions
  44. Metzeler enduro3 sahara tires
  45. How would a 2009 KLX250 compare?
  46. Clutch shaft help
  47. Kinda nervous
  48. Moab 4-27 thru 5-12
  49. Battery not charging [2009 KLX]
  50. 2 '09-'10 tanks remaining
  51. Carb wire
  52. sprokets and o-ring
  53. Motorcycle carrier
  54. 2009 running way to lean
  55. 13T front sprocket
  56. 2007 KLX250: Valve clearances/shim replacement.
  57. Rear Suspension Sag
  58. 2007 KLX250: Front wheel maintenance
  59. Added Zeta Hand Guards w/signals, pics
  60. Leaking Acerbis Tank - Repair Options?
  61. anyone selling a used slip on for klx 250 ?
  62. Yo Deej Noooone of the Links in the Sticky FAQ Thread are Working
  63. How many chain links on an 09 klx 250s
  64. chargin battery
  65. Iphone (GPS) holder mount
  66. KLX fork and shock seals
  67. Here we go
  68. Powermadd handguards and G2 Moto handshields
  69. Project - Full Exhaust / DJ kit/smog removal complete
  70. jetting issue since big bore HELP
  71. Had a spill. Made a puddle.
  72. dynojet kit install pics, choke jet drill
  73. 250sf dynojet install
  74. 07 rotors don't work on an 09.
  75. Powermadd setup
  76. Air Duct install
  77. laid my bike down in front of the liscence bureau today.
  78. 0.018" drill bit source
  79. Oil filter
  80. FS: IMS footpegs
  81. Bike dies after an endo..
  82. For Sale - Forcefield armor pants
  83. Am I a tool for adding stickers?
  84. guards
  85. jetting
  86. Step 1 added new handlebars
  87. KLX300 Cylinder, Piston, & Gasket Kit
  88. KLX on the Indoor MX track.
  89. New 351-CLUB Member (pics) install
  90. Big Gun Evo r full system for sale
  91. What to do for an exhaust
  92. What Is This? Where does belong?
  93. Installing handguards on stock handlebars (How To)
  94. MX rear fender for '07?
  95. Cheap body armour
  96. Time warp
  97. 200 mile ride today
  98. 09 KLX250S For Sale
  99. repack fmf q4I
  100. Help with '07 rejet around Orange County, CA?
  101. Selling the KLX...too high a price?
  102. dumped bike in a ditch...please help!!
  103. Who is good with the electrical system?
  104. Frame/Disk/Fork guards for the KLX?
  105. Changing the gearing to match the 07?
  106. Carb tuning and throttle position questions
  107. Recomendations on a tank bag?
  108. Idle Jet???
  109. New 250s owner! interested in 250sf conversions.
  110. Freakish whistling sound from front of 09 KLX250 1700 miles.
  111. Good price on FMF PowerBomb Header and Muffler ($359.92)
  112. Installed AFR Gauge on KLX
  113. Air box
  114. Radiator shroud trade?
  115. Main Jet size with full exhaust
  116. Part-out - bottom end off 2007 KLX250s
  117. altitude
  118. 09/10 Stock Dunlop D605 tires, Worth Keeping?
  119. Cross-County trip - Dealing with Elevation Changes
  120. Motion Pro Rim Lock Weights
  121. 2006 KLX 250S Tail light
  122. Doubletake Mirror
  123. Riding gear
  124. How do I know if I am dangerous lean?
  125. spending spree
  126. Acerbis Tail light Question?
  127. dynojet
  128. electric plug
  129. Sagent to have new wide seat for KLX this summer
  130. New aluminium fram KLX possibly coming...
  131. Just a heads up on rotors
  132. 2009 model year changes?
  133. I don't know what I'm going to do with this.
  134. How many miles
  135. parts
  136. Goodridge brake lines
  137. New tires, HD tubes, and rimlocks.
  138. Exhaust Q's??/
  139. Rich or Lean: how to remember
  140. Side rack options
  141. new old questions
  142. 340 big bore - need head gasket..... Suggestions?
  143. Stock exhaust mods finished.
  144. Weird buzzing sound?
  145. Exhaust tip for KLX 300
  146. cheap 08 - 10 BLACK plastics
  147. Anyone who has taken apart the KLX motor - help please!
  148. Need interest in new product for KLX
  149. Newbie W/ Questions...help please!
  150. More mods completed
  151. Carb is leaking...
  152. The time has come.
  153. Distance commuting?
  154. FMF Q4 installed on 2010
  155. the ass u me r wants to thank yins!(noobie)
  156. FMF Powercore on AUS models
  157. Luggage rack
  158. Blue LCD
  159. found a new reason for the bike not to start
  160. Replacement Rotors
  161. Muzzy Header
  162. Tube Storage
  163. First ride today
  164. New in CT with new to me, 09 KLX250sf
  165. Do you let friends ride your bike?
  166. And now for something different; KLX250sf
  167. C/S sprocket removal
  168. prob.cold start,noobie..
  169. FMF end can - bad fitting
  170. Installed Edge2 tail light tonight
  171. Where to get SM rims?
  172. noobie
  173. Longer Throttle Cable for 06 -07 bikes
  174. How to remove the pixie stick out of stock can ?
  175. Flexx bars on klx250s?
  176. Battery charging station
  177. Handlebar foam pad
  178. Switching off headlight to free-up some watts?
  179. Spark plug removal difficulty
  180. You guys in New Zealand OK?
  181. Lot of Mikuni jets
  182. Long shot - but anyone have a left side crank case they want to sell? (2007)
  183. Looking for rear ugly mudflap thing for an 09'
  184. Another beautiful KLX day.
  185. Cheap 09 KLX 250s, low miles!
  186. Help me buy a new end can
  187. Pro Taper ATV Hi Bars
  188. DOT knobs installed
  189. Time to graduate to a 450
  190. IMS tank for sale, $50....
  191. new 09 plastics
  192. For Sale Kouba lowering links. Fit 2007
  193. Oil Filter toqure?
  194. KLX351 vs. DRZ400
  195. FMF Q4 issue on a 2007
  196. Edge2 tail light
  197. Newest KLX addition
  198. 351 kit without the carb.
  199. Anyone in Seattle?
  200. chain brand, renthal or d.i.d
  201. New Rack
  202. New Awesome Tires on my SF and PISSED!
  203. klx 351 vs Yamaha wr 250
  204. Picked up my '09 KLX250SF today (update on IMS gas tanks)
  205. Doing a 340 - jetting suggestions???
  206. Ran out of gas
  207. 2009 brake rotor
  208. I just went for a ride. Wardrobe malfunction.
  209. Smog stuff. My bike does not have what is in this picture?
  210. Question for anyone around sea level
  211. Edge kit & Zeta's
  212. Garage day...
  213. Steering Dampeners
  214. KLX250sf tail kit ?
  215. K&N Air Filter for the 09SF
  216. KLXs shorter springs in AUS
  217. Strange Markings on Engine
  218. Idle Problems, think I know the answer?
  219. Time to upgrade the klx a few Q's first...
  220. Sprockets
  221. Wharton State Forest, Is It Snow Free?
  222. How do I accurately judge equiptment change
  223. Opening up the 09 KLX250S
  224. Installed my FMF muffler tonight
  225. 07 KLX250s Problems
  226. klx in snow with A.D. Boivin explorer
  227. EFI 300? is it possible?
  228. Springs
  229. Colorado Ride Report August 2010
  230. Anyone have Soupy's lowering links?
  231. Another way to skin a carb
  232. A Good Day to Ride - The Video
  233. Another MotoPro fork valving question
  234. Stock Fork Valves
  235. Which states are easy to make an off road cycle street legal?
  236. Add on kick start
  237. Happy Birthday EMS_0525!!!
  238. Carb Jets and exhaust 2007 KLX 250
  239. Selling the KLX
  240. hiflo vs unifilter
  241. FSW KLX300 Header NEW For Sale
  242. Wanted: IMS Tank
  243. Skid/Bash Plates
  244. For those of you whinging about it being too cold...
  245. NJ Pine Barrens (NE II?) ride?
  246. FMF Q4 Powercore Slip On
  247. Dynojet kit for sale
  248. Anyone have the Thor M1 boots?
  249. 06 shocks
  250. Mesh removal
