Handlebar foam pad
Hey guys,Is it possible to fit a handlebar / pad / foam thingy to a stock handlebar or do you need to switch out the handlebars to something similar like that on a BMX? With a supporting bar.
I'd like to get one but I have just the stock bars.
Maybe I'm missing something? But I can't see how one would snuggly fit on otherwise.
Well, that is acctually the crossbar, that's what Protaper and renthal uses, I have ones similar to those, I'm not sure exactly which ones but they look like them...
They work just fine
They work just fine
Most of those are just like what bmx bikes use. They are typically cut to the size of a motorcycle crossbar for conventional bars and would fit most all bars with crossbars. I don't use the pads so I installed it on my 6 yr old son's bmx bike.
I put a fox pad on my stock bars, it''s green to match the bike and I had to manipulate it around some to look ok but in the end it looks fine. I did it as I like how it looks but I did have a crash years ago where my head hit an unpadded one pretty good.
I recently bent my stock bar on a slow sped crash. The stock one's are steel and heavy. I replaced it with an aluminum one.The pad would fit on a stock set, I had one on temporarily.
well i can tell you this, when i was in 9th grade, im in 12th now, i was on my CRF 150 and i went off a very big jump that a neighbor of mine made and i went too fast... i came down and slammed my chin on the handlebars, unfortunatley i missed the pad and split my chin open for the second time.... got 6 stitches. i wil always use a pad.
