Handlebar foam pad
Old Feb 23, 2011 | 01:31 PM
TheDoc46's Avatar
Default Handlebar foam pad
Hey guys,
Is it possible to fit a handlebar / pad / foam thingy to a stock handlebar or do you need to switch out the handlebars to something similar like that on a BMX? With a supporting bar.
I'd like to get one but I have just the stock bars.
Maybe I'm missing something? But I can't see how one would snuggly fit on otherwise.
Old Feb 23, 2011 | 01:46 PM
thejackcutts's Avatar
You might be better off getting other bars, I fell one time, it wasn't even a bad fall, more like a slip, but still, they bent, so I got some protapers.
Old Feb 23, 2011 | 02:20 PM
TheDoc46's Avatar
What about these? The are bars without the crossbar, but with the pad looks like its being held in by those brackets. Looks cool.
Old Feb 23, 2011 | 02:33 PM
Well, that is acctually the crossbar, that's what Protaper and renthal uses, I have ones similar to those, I'm not sure exactly which ones but they look like them...
They work just fine
Old Feb 23, 2011 | 03:05 PM
Stroker331's Avatar
Most of those are just like what bmx bikes use. They are typically cut to the size of a motorcycle crossbar for conventional bars and would fit most all bars with crossbars. I don't use the pads so I installed it on my 6 yr old son's bmx bike.
Old Feb 23, 2011 | 03:14 PM
linkin5's Avatar
I put a fox pad on my stock bars, it''s green to match the bike and I had to manipulate it around some to look ok but in the end it looks fine. I did it as I like how it looks but I did have a crash years ago where my head hit an unpadded one pretty good.
Old Feb 23, 2011 | 03:31 PM
tom edison's Avatar
I recently bent my stock bar on a slow sped crash. The stock one's are steel and heavy. I replaced it with an aluminum one.The pad would fit on a stock set, I had one on temporarily.
Old Feb 23, 2011 | 05:10 PM
Feral Donkey's Avatar
Tusk makes a foam thingy for kid's bikes that works perfect. Look on RMATV.
Old Feb 23, 2011 | 05:20 PM
well i can tell you this, when i was in 9th grade, im in 12th now, i was on my CRF 150 and i went off a very big jump that a neighbor of mine made and i went too fast... i came down and slammed my chin on the handlebars, unfortunatley i missed the pad and split my chin open for the second time.... got 6 stitches. i wil always use a pad.
Old Feb 23, 2011 | 05:54 PM
Stroker331's Avatar
I need the dashboard room so a computer and rollchart cushions my face if it needs to head towards the crossbar
