Dumb question
Old Mar 27, 2011 | 08:36 PM
YANK's Avatar
Default Dumb question
I know its probably simple as heck,but how do you take the throtle cables off the carb LOL. I dont have a clue.
Thanks Rick
Old Mar 27, 2011 | 09:05 PM
Most the instructions I read said to loosen the cables (at the carb, I believe), but to be very conscious of the number of turns on the connectors so that they could be put back the same or risk messing up the push/pull adjustment on the throttle.
I just use a needle-nose or forceps to remove the cables from their "socket" then unscrew that phillips head holding on the cable-connector mechanism so that no risk of messing with the push/pull adjustment. It takes a little wiggling, and it helps if the carb can be loosened and twisted a bit to remove the cable-connector mechanism from around the vent tube.
klx250scott
Jan 27, 2009 12:05 PM
TheMaverick
Mar 11, 2007 08:25 AM
bryantjt
Aug 30, 2006 03:09 PM
jared
Ninja 250R
Jul 30, 2006 12:40 AM
littledevil
May 8, 2006 09:14 PM
