View Full Version : KLX 250S
- Let's talk about my ass....and an aftermarket seat
- Linky to suspension info
- Help needed. Help appreciated!
- Got my new Shinko's on my SF
- The KLX aftermarket is awful!
- gear leaver oil leaking
- Muzzy Status?
- Head ight bulb
- 2007 KLX250 triple clamp spacing
- eratic carb behaviour
- folding levers?
- Which year model to choose?
- My first tyre change!
- 351 Install Help
- Suspension Adjusting... :)
- Help with raising forks / handlebar
- does this fan ever work?
- Airbox, EFI, wut?
- why does crf100 have more snap than my 250?
- Need DOT approved tail light
- Do I need new rings? 351bb
- Best Tires for 30%/70% Street/Dirt Use...
- Need a better seat..
- Change front or rear sprocket?
- Front Sprocket Oreintation
- Rear brake fluid reservoir looks empty?
- Dead battery? Help
- Emissions equipment and cherry red exhaust myths
- How to reset clock? And pannier bracket mounting?
- I need some help from riders I've helped...
- New Bike, Squeaky New?
- This Really Sucks!
- Quick tech help needed broken fork clamp stud
- New 2014 KLX 250s Air Filter Warning?
- WTF is up with my left fork leg?
- Klxster's CDI Ignition Curve Project
- Significance of Ignition Timing on US KLX250s...
- Mid range rpm noise
- 06-07 KLX250s Will KLX300R wheels work? Any other choices?
- Gearing for two wheels
- Octopus/Jellyfish Vent Hoses on Gas Tank...
- DJ to Keihin Jet conversion chart.
- rear wheel for 2011 klx250s
- MASSIVE differences between N1TC clip positions....
- Stumble between idle and mid throttle
- Rear Spring Upgrade
- sidestand and clutch safety switch removal question
- klx250s 4000km race
- Help Part Identification
- run the KLX with no mods?
- Request: Pictures of cable/wire routing under gas tank
- IMS Plastic tank shroud bolt insert spinning in tank......???? Now what...????
- Devol 1" Lowering Link
- Clarke gas tank installation (06-07 models)
- Bent front rotor - are rotor protectors worth the cash?
- Buying a KLX
- Dyno Chart Stock KLX250S
- I need a gas cap, anyone have one?
- Video: Valve Clearance Check
- aftermarket dirt wheels?
- OEM Plastics
- Acerbis Supermoto Front Fender
- Wheel interchange
- Bike dies after 7 miles, checked everything, need help....?????
- KLX 250 Graphics Decals Stickers
- Big bore vibrations
- 2009 klx 250s EFI hard to start
- Brake/Clutch levers: OEM vs CNC Pivot style & Shorty
- Lid-less with Keihin MJ and Needles
- Stock spring rates and intended weight
- Are All Dynojet 2152 kits the same ?
- Stock Exhaust Mod???
- Front Fender Brace
- Klr
- Rear Brake Light Harness - Connector or NO?
- 06 klx250s suspension questions
- Building a wee Beastie
- Free JNS Engineering Light Mounts!
- Maintenance of heavily modified KLX 250
- KLX250SF runs and rides fine, then slowly dies
- which slip-on exhaust is on your 2007 KLX250S?
- intro and first mods..will i need carb jetting?
- TM36-68 Tuning?
- What is this part and why is it capped ?
- Radiator shourd plastic search 09-13
- second set of complete wheels cheap
- ADV 101: Using the KLX250s as an Adventure Bike (ARL's Motovlog)
- Sprocket and Airbox mod (UPGRADES)
- New Member
- speedo error on SF also?
- Public Safety Announcement: Engine performance optimization creates unsafe condition.
- kawasaki 14069-1051 BREATHER
- Used KLS250S Purchase
- DynoJet source?
- Snirt run 2016
- 1993 KX fork swap
- Suspension mods for 06-07 KLX250s
- Pro Taper bars not fitting 250SF?
- Question about replacing broken gear change shaft
- Front Fender: Acerbis vs UFO vs Cycra
- Technical Trail Bikes Comparison Table
- Strange wear on 351 big bore kit
- Only getting 13.5V......With solution!!!!
- Linkage and swingarm pivot bolts - best grease to use
- klx 250 sf
- Oil Change, where are the parts online?
- 07 Start-Kill Button/Switch Change
- Engine noise I'm noticing under acceleration
- Spring ride on Illabot Creek Road....
- Acerbis auxillary fuel tank
- Looking for a low buck dual sport jacket? Check this out
- TM36-68 Air Jet?
- Klx250s klx 300R motor swap.
- KLX250 to KLX351 Exhaust Sound
- Difference between klx250e and klx250s
- OEM KLX300R header, mega bomb, or mega bomb knockoff?
- BRP Triple Clamp TCA-5610 (for KLX300R)
- praise for IMS tanks (customer service)
- KLX300 Tank on a KLX250?
- air filter fitting
- WTB Stock Suspension Rods for 2007 KLX 250
- Number plate backgrounds
- Wheel off different bike
- Problem with 2009 KLX 250sf
- It's Alive!
- How thick is the mixture screw plug
- New collector exhaust klx250
- IMS tank leaking
- Last week's crash
- 1st 2016 Spring Ride
- Ride report
- 02 klx300 wheels on klx250s
- Opinions & WTB KLX 250sf skid plate...
- WTB chain guard for 07 klx250s
- Can a welder fix this?
- Suspension setup for 190lb rider on 2006 KLX 250s
- 2007 KLX250 Wiring Damage
- electrial issues
- TM36-68 Running both Stock Cables
- Anyone add a centerstand? Good idea or not and why?
- Gearing...
- More carb problems
- Looking for a new head, cap and cams.
- Need help find a new motor
- Glowing Red Headpipe on 351 BB
- two brothers racing exhuast
- How do kenda k760 do on the road?
- need cylinders
- Driving, not riding, to work...
- Help find 2006 klx 250s top end
- ARC Timing?
- Bye bye Klx250s
- K&N oil filters ?
- Different rear fender?
- 2006 KLX Plastics
- side stand slop
- kenda 761
- Effects of Restricting Exhaust?
- Dynojet Kit for 2007 KLX250
- Tm36-68?
- Best plus size gas tank for 2006-2007 KLX 250s?
- Everything cuts on start
- 06-07 levers same as 08+?
- Strange starting problem, NOT fixed.
- Strange starting problem, fixed?
- Bent handlebars, which ones do you recommend ?
- Question to those with the 351 kit
- '06 dies when throttle opened
- getting ready to re-jet
- Looking to Trade or Buy Green Shrouds for Black.
- DRZ400 Motor in a KLX250?
- Short Levers
- putting a new brake light in
- 2012 klx250s value w/700 miles
- KLX 250S FI lamp idle 3k problem
- Brake pads - Pros cons?
- New front rim for my 06 KLX25S
- BB 351 or BB331?
- Company in Canada doing the Big Bore Kit?
- 2009 KLX250S not getting spark
- Ordered IMS tank......
- New KLX250S owner
- Replacing Steering Head Bearings - Tools?
- Looking to get a KLX250s
- Bike has not been road-ed for over a year - safety checklist before streeting it?
- How to adjust idle mix screw while carbs on the bike
- Klx250s
- Klx 250 s `14 Impressions from Germany
- OEM skid plate any good?
- Switched power for accessory, where to tap?
- 2006 klx 250 for sale
- 2009 Vs 2014 KLX 250S
- Questions on my new 06 KLX
- lacing 17s to stock hubs
- new to klx
- Finally back!!
- Looking for larger aftermarket gas tank...
- 2007 KlX250S spokes
- 2007: Looking for tank and Panniers
- FS: Pirelli Diablo Rosso II rear tire 140/70/17
- Problems after EFI BB331 install
- Upgrades so far - what next?
- Thinking extra gas.......
- Best tank bag for '13 KLX250?
- Oversize handlebar advantages?
- KLX250s different wheel sizes?
- Is Float Causing Death?
- Help me get this monster performing optimal!
- Supermoto to dirt rims. HELP!!!
- '09 KLX250s steering damper
- The Off Season
- DG exhaust year?
- KLX's
- KLX250 Rims
- BB331 Install Problems - Help Needed
- Bought a used 07, regret it so far...
- Best cover for '13 KLX250s
- Connecting vacuum gauge to engine
- Bmw f650gs ~2005
- Other KLX 250s Items for Sale
- 2010 KLX 250s For Sale $2,800
- 06/07 suspension on an 09+ bike
- My head hurts
- Tear down to frame?
- Extended Side Stand Options
- Thanks Everyone
- How to modify this motorcycle lift
- Mystery writing
- What up losers?
- Known Issues
- Kx --> klx
- 100 Mile Sunday Ride
- KLX as an adventure tourer? '06-07' vs +'09?
- Racing in the streets
- Cush drive
- 2012 KLX won't idle after jet intall
- Ok y'all. Bought an older KLX250
- For Sale PMR Rack - NEW
- Swingarm Decals
- Clutch slipping 101
- FS: Happy Trails GIVI E21 rack system and topcase rack
- FMF Powerbomb header expectations ?
- Battery Recommendations with higher CCA for the KLX351 ?
- Need to borrow some expertise on modding...
- Removable Turn Signal Mod for $12
- Alibaba/Aliexpress KLX300 kits
- Tci Windshield brackets
- Replace rear pads without removing caliper?
- Motor swap pro tips
- Galfer brake line for 2014 KLX250S fit
