S vs SF forks
Old Apr 30, 2013 | 02:40 AM
cegusman's Avatar
Default S vs SF forks
What is the difference internally between them? Was wondering if there was just a spacer and shorter spring in the SF. Can you pull the spaced and install the longer spring?
Old May 1, 2013 | 03:38 AM
cegusman's Avatar
anyone?
Old May 1, 2013 | 05:19 AM
RockabillSlapMatt's Avatar
inverted
Old May 1, 2013 | 11:30 AM
wildcard's Avatar
I don't know, I would imagine you are correct in your thinking.
AFAIK no-one here on the forum has been into the SF forks that far, at least I don't remember seeing anyone posting about taking the forks apart.
Old May 1, 2013 | 11:48 AM
I doubt there is a spacer. The SF has a stiffer spring rate.
Looking at the online fiche between 2010 S & SF, the only different part number is the spring.
Old May 1, 2013 | 01:38 PM
cmott426's Avatar
There has to be something since the SF has less travel.
Old May 1, 2013 | 03:02 PM
Everything is the same in the exploded view of the forks....
Excidium28
Nov 1, 2007 02:28 AM
foggys916
Oct 5, 2007 05:24 PM
KZJim
Jun 11, 2006 02:55 AM
KZJim
Jun 3, 2006 10:40 PM
onewheel
Feb 2, 2005 02:44 AM
