S vs SF forks
What is the difference internally between them? Was wondering if there was just a spacer and shorter spring in the SF. Can you pull the spaced and install the longer spring?
anyone?
inverted
I don't know, I would imagine you are correct in your thinking.
AFAIK no-one here on the forum has been into the SF forks that far, at least I don't remember seeing anyone posting about taking the forks apart. |
I doubt there is a spacer. The SF has a stiffer spring rate.
Looking at the online fiche between 2010 S & SF, the only different part number is the spring. |
There has to be something since the SF has less travel.
Originally Posted by cmott426
(Post 494740)
