Bike stalls when clutch engages
My bike has decided to shut down as soon as I put it in gear, and release the clutch lever. It runs fine in neutral. I can even put it in gear, and it's ok until I start to pull away. The only thing I can think of is the side stand safety switch. Any other ideas, before I bypass it?
Newbies take note: search first, ask second.
I checked around, found a link that explained just how easy bypassing the kick stand safety switch is, bypassed said switch in about 3 minutes, and now have a properly running KLX.
FML
FML
It has never given me trouble and if it did, I would repair it at the first opportunity. I guess that's the risk you run bypassing safety devices. Would you bypass the kill switch if faulty?
I disabled mine trailside because it was killing the motor in the rough stuff.
I just trained myself to double check the kickstand. I often kick it out of the way, go to let the clutch out, and kick it out of the way, only to realize I already did it.
I have yet to ride off with the stand down.
It's just like flying, it's part of my pre-flight checks now.
I took mine off because I didn't want my engine to unexpectedly die on me and not know what was going on. I've never had a problem remembering to kick it up. As soon as I sit on the bike it compresses and I can feel the kickstand hit the ground.
I must not be the only one to forget as OEM's avoid the installation of unnecessary components (unless they're bound by legislation e.g. anti-smog equipment) as it raises cost & complexity during production.
