Carb Icing?
Old May 16, 2013 | 05:08 AM
Karitane Pete's Avatar
Default Carb Icing?
Hi Guys, how do you stop a carb from icing?
this happens at about 8 deg C at sea level in foggy weather.
Old May 16, 2013 | 05:44 AM
Lotrat's Avatar
You can't stop it. You need to introduce a heat source to melt it as it forms.
A heat riser off the exhaust is common for cars. The short intake on bikes limits the exposure to carb icing, but it still can happen. They make carb heaters for some bikes. Haven't had a need for them in San Diego. Here's what they look like:
Not sure if there is an off-the-shelf solution for the KLX250S.
Old May 16, 2013 | 09:30 AM
250SM's Avatar
Here in Australia our KLX came with a carb de-ice circuit. You could find out the part number and order it from ya dealer.
Old May 16, 2013 | 10:08 AM
Yerr saw that in the service manual, can it be fitted to the carb or is it part of the carb?
Old May 16, 2013 | 11:55 PM
Does anyone removed the carb heater from their KLX and would be will to part with it?
any one nearby in Aus maybe?
this would be easyer than building one from sratch
Old May 18, 2013 | 06:22 AM
Lotrat's Avatar
The AU option for carb heat is a different carb with a coolant loop through it. You'd need a new carb and all the plumbing to make it work.
Old May 18, 2013 | 08:37 AM
250SM's Avatar
Theres no loop in the carb.
Old May 18, 2013 | 01:35 PM
Lotrat's Avatar
Ah, I see. The drawing in the manual makes it hard to tell what the system is. So it just heats up that post on the bottom of the carb? If so, it's just plumbing.
Old May 19, 2013 | 12:42 AM
Yes, if someone (in Aus?) had the T and the plumbing laying around looking for a new home please let me Know.
jkd6h
Sep 6, 2012 01:03 PM
Arctra
Nov 21, 2010 11:48 AM
horizonod
Nov 15, 2008 12:38 PM
cokrkilr
Nov 22, 2006 03:28 AM
