View Full Version : KLX 250S
- Kudos to that Mooredan guy
- '09 ran rough after crash. Thoughts?
- Backfiring when shifting with 1/4 throttle
- US vs AUS CDI
- 2011klx250s
- FI light with PCV?!
- New FMF Powercore 4 smoking
- Knobby Knife
- Gas Mileage?
- Copper Basin Ride Report
- FMF Q4: 2006/07 vs 2009+
- Rear Chain Guide for 2009 klx250s
- TM36 and Acerbis tank
- Ride Report.....kinda
- KLX sending me to get sliced and diced again :(
- FS FMF Q4, edge 2 tail with 12 o'clock labs board.
- Scala Rider intercom
- Wanted*** rear reflectors
- exhaust getting beat on...
- IMS tank with pumper carb?
- Stock Carb vs. 300R carb with ACV
- Muffler
- TBR pipe/PX3 quiet core/SW Motech skidplate $260
- Which Trailtech Vapor model fits...
- Case savers the same on all KLX models?
- Hey, Are Any of the Original Old Time Posters Still Here?
- can be 350 kit flooded by TM36?
- Could I use the kick starter from a klx650 or any other parts?
- Oregon Dunes
- Noise after engine warmed up
- Broken Speedo and some Panniers
- LED blinkers and taillight install question
- '09 KLX - Hard to Start
- engine cut out
- Megabomb welding question
- New KLX250 for me!
- FS: Off Road wheels for SF
- starting with TM36, first impressions
- SW Motech skidplate
- I'm moving on...
- Ebay Deals!
- KLX Riders on Facebook
- stripped header stud bolt.
- Fully Farkled KLX250S for sale
- F/S SF wheels
- New Aussie KLX250s Question re: DJ Kit
- My SF is for sale. :(
- after klx250s/sf?
- Cams alignment?
- lost DJ stage 1 kit needle spacers
- Whale Tail
- Oil Leak
- Not happy with Scorpion Pro
- megabomb header melting airbox issue
- Just picked up a 2009 KLX250s (CA MODEL)
- megabomb review
- Where to buy new plastics for KLX250S?
- Question on front tire size
- A thought for new (and old) members
- Just relocated to Glendora, CA (SoCal)
- purpose of crAnk vent mod?
- selling my 2010 klx250sf
- Help me win a contest.
- New Member
- Heat Shield
- Took some bikes on a trip.
- 250 bogging in a certain RPM range.
- Bigger rear tire and gearing
- IMS Tank Bag?
- sand tires do you think i could get away with it?
- Where's the best place to buy tires
- 2010 klx 351 timing issues !!!!!!!!!!
- i'm buying a new left case how do i keep it from happening again?
- What performance numbers are you getting on your KLX250S
- Fork seals blown, again.
- Front axle
- Durielk & TNC in Colorado
- rod length, pin diam
- Buying Wolfman Luggage in Canada
- Standard Non-O-Ring Chain Care Tips?
- New owner of older KLX250 drives an Aerostar?
- Exhaust and Header, please help!
- a question for others in WA, or maybe suggestions for a good DS bike forsomeone small
- SF 17" wheels, tubed or tubeless
- Broke the Magic Button...
- Shifting Problems
- 2007 KLX250 bad tachometer, and break light
- I want your stock gas tank
- What Was That Cracking Sound?
- Two out of three bikes down; riding KLX to work!
- How to replace OEM Engline Plugs with ZETA plugs on KLX 250
- Jetting my carb back to stock, need help with fuel screw turns etc.
- Getting a VeeStrom 650
- Help diagnosing a problem - no electric
- F/S Sargent seat!
- Short video on the way home
- Keepin my eyes out for a Green DRZ (KLX400)
- Struggling to Get 2009 KLX250S to Rev >5,000 RPM
- Who's got & uses a GoPro???
- header turnig red all of a sudden????
- 351 Power Numbers
- 2012 D-tracker 250 thailand my mods
- 2007 KLX250S Tire Sizing
- KLX Touring Setup (Pics)
- Shifter shaft seal replacement
- KLX stranded me this morning...
- Replacement carburator
- New tires date, would U keep em?
- Factory Skid Plates
- My short HD KLX250s video
- shock damping too high
- murrieta to lompoc and back, me and my dad, the ride report kinda
- Old Lurker, New Member
- DRC silicone hose problem.
- 07 250s speedo not working right
- Sprockets
- Is the KF search function broken or am I doing something wrong?
- jet options for 2006 klx 250s
- Keihin jet with DJ jet?
- Pilot screw tool
- PSI With No Rim Locks
- KLX 250 Rear Fender Flops
- Kawasaki KLX 250 EFI '09 for sell
- oh crap, Arai xd-4 explore ordered
- Painting head cover
- New Kawasakis from Costco
- Suzuki TU250x
- AFRAID! I might have solved my problem
- 2009 Head Cover Gasket
- Stebel Nautilus horn
- Ideas for removing these rusty nuts....(pics)
- Introduction and a few questions inside about a new KLX250S.
- 2009 klx351 for sale on ADV
- Shift Levers
- Diaphram in hot water??
- Transmission woes...
- Plug wrench aka Does this bike make my fingers look fat?
- selling my 2012 250s :(
- Headin' to Silverton in the AM
- F/S W.E.R. Steering damper
- Hanging idle
- Riding with the GoPro
- New Owner
- Wind/Speed Wobbles
- carb is smart, I am not
- Best old fashion style "paper" enduro magazine??
- Another "Jetting with Mods" Question
- Honda CRF450X
- Shared Exhaust?
- Anyone use a rewound stator? Or more importantly what electrical loads do you run?
- 94 klx 250 headache
- tube or tubeless?
- Shift Shaft Seal - 2006 KLX250
- FS: Red frt fender and side panels
- FS: FMF PCore-DynoJet-UniFilt-KoubaScrew-KDXsnorkl-ALL NEW
- FS: TCI Boreggo Rack wPelican Case
- FS: TCI Windscreen
- KLX's aren't bought they are grow out of the ground
- My New Ride! (&1 Question)
- F/S Ricochet skid plate
- click noise from newly installed Zeta throttle
- FS: Stock Tail Light Assembly
- 2013 Husqvarna TR650 Strada
- 19" wheel?
- Honda crf250L.....
- Have to sell my baby.
- brakes
- Homemade Wolfman Ripoff
- Going part shopping for my KLX250S
- Looking for Daniel D. on AOL about cam chain tensioner
- Tack gauge cover
- Heavier front spring rates
- Crf230sm - crf230l
- Rubber ring thingy on the front wheel ????
- 2006 KLX250s with Muzzy Header - Need Pipe Guard
- I could get hooked on this...
- Feeler - Selling 09+ S wheels
- EFI Idle problem
- 351 Install complete
- Does it have a cat?
- 1994 klx250r
- Some new mods
- Rejet for Elevation. Wow.
- Valve Adjustment
- New KLR Owner
- Clip position vs jet size
- Preventing rust on headpipe?
- NEW to KLX250S/Dual Sports
- Heel Guard
- Bar Pad Size
- Trials tire
- Kickstand - Adjustable
- KLX300 skidplate fit 07 250s?
- KLX250S upgrade parts 2009+
- Classified ads section
- airbox cover/snorkel on stock EFI models
- How to lower my 2009 KLX 250s without link
- Need a new air filter
- Replacing FR sprocket. Lube question.
- F/S Gas Tanks
- Downshifting and ending up in neutral
- ***Smog removal plug CHECK***
- Non-running KLX
- Rejet comments from Dyno Jet
- Well, now I'm in a pinch.
- Pictures of new Seat Concepts saddle
- 2013 KLX250S on the Kawasaki USA website
- 2010 klx250sf turned 351 issues!!!!!!!!!
- Supersprox 51T Rear Chainwheel
- KLX250-Noob Concerns & Questions-
- relocating to Los Angeles area
- off topic: for sale KLX250S fuel tank
- Not sure I like it.......
- slide hole
- TM33/34 Pumper/Motion Pro Vortex throttle combo
- Big bore the KLX or buy somethng new?
- sputtering (a bit) until fully warmed up
- Master Link - 2006 KLX250
- Selling the KLX - do you guys allow for test rides?
- headlight/taillight killswitch
- Help me figure out what's wrong...
- harder to do a wheelie
- 2nd accelerator cable
- What are those?
- klx 250R muffler
- Colorado Trip Preperations
- Oil filter question
- Another tires thread
- want to remove snorkel / adding megabomb.. jetting suggestions?
- '06 KLX250S What Upgrades to Make?
- Cartridge holding tools
- 300 muffler/header
- Sold my KLX and bought...
- 2nd gear wheelies?
- help with edge tail light kit
- What to expect with a 300 kit?
- rear tire leak
- Why not go to a Local Machine Shop?
- Clutch spring bolt torque spec
- Don't Forget, Enduro X is on tonight
- Ims+tm36+....
- squishy front brake lever?
- Cooling Fan Malfunction?
- My baby's back . Missed you baaad
- New Tires
- Rear springs
- Flooded bike in the middle of the Everglades!
- Needing a Bill Blue TM34 Carb
- Rear wheel axle nut
- changing jetting from stock to megabomb header
