What I/you did today on the bike
Old May 17, 2017 | 11:29 PM
  #231
snappster's Avatar
My Magna is back running well and the klx was lonely so I just spooned on a new front IRC RX01 stock spec tire. The old one was likely the original dated 2008 with a couple thousand miles of tread left but the rubber was hard and grip unacceptable where I could skid the front tire on clean dry asphalt using only two fingers on the lever making wonder how much of my grip budget I am using in curves. Hell, I am on the second rear tire and it is at the wear bars, might as well pony up for that now. Tomorrow we'll be spooning a new front tire on Maggie. It's 5 years old with less than 2000 miles on it but it skids easy too. I wonder how I survived until now not knowing old tires were asking for a crash.
Old May 22, 2017 | 07:26 PM
  #232
MaximusPrime's Avatar
Managed to take 2 bad wheels and make one good one.
Used a spoke kit for a KDX wheel. I had to drill out the spoke holes to use the nipples that came with the kit.
Re-lace took about 45 minutes and another 45 for tightening and truing.
Put a double layer of Gorilla tape on as a rim strip, mounted a tire, and went for a test ride.
75 miles later, I jacked up the bike and rechecked spoke tension.
Old May 26, 2017 | 05:00 AM
  #233
jabara572's Avatar
Put some factory race team graphics on my rear fender (kx450f fender), except I cut the white out of it.
Attached Thumbnails What I/you did today on the bike-20170526_004231.jpg
Old May 30, 2017 | 12:16 AM
  #234
s10gto's Avatar
Looks good!
I just looked at mine today. Raining
Old Jun 2, 2017 | 07:18 PM
  #235
jabara572's Avatar
Found a nifty spot under the seat in front of the airbox for a small storage bag, i keep a CO2 inflator in there and a few co2 cartriges. I think the bag is a little accessory bag i got off an otterbox case for an iPad. Hey it got some more stuff put of my backpack. Im happy, you could probably fit a spark plug andba fuse or two in there also
Attached Thumbnails What I/you did today on the bike-20170602_002705.jpg
Old Jun 2, 2017 | 07:42 PM
  #236
Klxster's Avatar
What might be the effects of this mod to airflow ( airflow to the airbox ) ??
Old Jun 2, 2017 | 07:55 PM
  #237
jabara572's Avatar
Probably nothing would be my guess.... the "hook" for the seat goes right there and the bottom of the seat almost seals off the front of the airbox anyway, plus there is a big piece of frame and shock there already.
Maybe if there was some of "ram air" effect that may have been happening then maybe, but i doubt it, if anything it probably blocks some hot air coming off the engine from going into the airbox.
I guess the airbox gets its air from the space between the top of the box and the bottom of the seat (pretty terrible design IMO), which this bag doesnt affect, so I dont think it would affect flow rate through the filter at all but i dunno...
Old Jun 2, 2017 | 09:58 PM
  #238
NEWPARTSRULE's Avatar
Cool
Max, Your wheel is way cool. Time for another turkey.
Old Jun 5, 2017 | 10:20 PM
  #239
Tacoma660's Avatar
Removed the clutch cable guide above the radiator hose and removed the metal bracket in front of the rear shock holding down the vent hoses. Didn't see the point of having them so they were removed
Old Jun 6, 2017 | 07:48 PM
  #240
Tacoma660's Avatar
Removed the side stand safety switch
