97'' en500 ltd with oil in the airbox
Old 04-11-2009, 02:53 PM
AFWbass's Avatar
Default 97'' en500 ltd with oil in the airbox
I crashed my 500 about 2 years ago, and when my leg healed, fixed the broken shifter, handlebars, and footpeg and got back on. Only problem is that after i got it running again, i noticed it was seriously pouring oil mixed with gas out from behind the starter relay somewhere in my airbox. Took everything off and opened it up and sure enough, theres a puddle of oil mixed with gas in the airbox. SO, it starts fine and runs strong, but after about 10 minutes the airbox fills up to the point where the mixture overflows onto the left side of the exhaust and the chain. Theres a few air tubes that run to the box which are all dry, but theres a metal hose connecting the oil reservoir in the crankcase to the airbox that is covered in gross oil and im wondering if the oil is comming from there. But where is the gas getting into it? and how do i stop it?
Anyone else have this problem before? Ive been searching and searching for days but cant find anything other than possibly a failing oil pump.
Old 04-11-2009, 03:04 PM
Odimus's Avatar
Welcome to the Forums!!! what happened to the bike during the accident??? did the bike flip over or something???
Old 04-11-2009, 03:28 PM
AFWbass's Avatar
it was layed down on its left side and skidded about 10 feet before we both stopped. going over assorted bumps and pits in the road in the process
Old 04-11-2009, 03:30 PM
AFWbass's Avatar
AFWbass's Avatar
Old 04-11-2009, 03:31 PM
AFWbass's Avatar
Old 04-11-2009, 03:33 PM
AFWbass's Avatar
first picture is where the mixture leaves the airbox onto the left side of my bike,
second is the opening for the oil breather in the airbox (suspect)
third is that breather tube running from the oil case in the rear of my crankcase running to the airbox above
Old 04-14-2009, 02:27 PM
cougarkid's Avatar
Check the oil and see if there is any gas in it.
I had this problem after sitting for the winter.
It would blow oil/gas into the air box through the Vent from the crank.
Gas had run through the carb and filled the crank case.
Not a good thing.
See my post: "91 ZX600 Engine Trouble" in General Tech
https://www.kawasakiforums.com/forum...ad.php?t=27392
Hope this helps, but then I hope this is not the problem, too.
Mike
Old 04-15-2009, 09:23 AM
Kinda sounds like this may be the issue. Welcome to KF
Baronthefirst
500 LTD
04-18-2013 01:55 AM
Gator73
08-10-2008 03:40 AM
steamchief
2000 & 2000 Limited
07-05-2008 01:27 PM
kwandrsn
11-17-2007 03:51 AM
kawi636
04-04-2006 09:26 PM
Quick Reply: 97'' en500 ltd with oil in the airbox
