What I/you did today on the bike
Old Jul 13, 2017 | 02:42 PM
  #271
snappster's Avatar
Originally Posted by Klxster
Ok... You gonna attempt to fuel your 351 with your 250 CVK setup..?
Mais oui mon frere.
https://www.google.com/url?sa=t&rct=...f2r3HnVI8YUFVw
https://www.google.com/url?sa=t&rct=...B-5TGQ&cad=rjt
Old Jul 13, 2017 | 03:13 PM
  #272
Klxster's Avatar
Je m'attendais à ce que vous choisissiez un chemin différent.
Old Jul 13, 2017 | 09:13 PM
  #273
snappster's Avatar
Had to run a translation as my 2 years of French language in the early 1980's is mostly forgotten. You remember more than I. Unsure what you are thinking though. But, drum roll please....the BB351 has arrived! Hooray, let the sweating in the garage begin.
Attached Thumbnails What I/you did today on the bike-image-34-.jpeg
Old Jul 14, 2017 | 01:05 AM
  #274
Klxster's Avatar
Ne pensez-vous pas que vous devez augmenter votre jet principal?
Old Jul 14, 2017 | 12:05 PM
  #275
Subseageorge's Avatar
Nice one, Hope you have a major success.
Old Jul 15, 2017 | 08:07 PM
  #276
snappster's Avatar
Default Dumb Question
In my BB351 kit box is a plate shaped like a small rectangle with two holes. Would somebody tell me what it is for?
Old Jul 15, 2017 | 08:39 PM
  #277
xcrcarpenter's Avatar
I think that I have read that it is to block off the smog deal on the front of the head. if you look directly above the exhaust outlet, between the frame and the head, you will see a part with the same footprint but instead of being a flat plate it has a small rubber hose going to it.
Old Jul 16, 2017 | 03:57 AM
  #278
Yes, there is an exhaust gas recycling valve for emissions i think. I did away with it all together,,
Old Jul 19, 2017 | 12:33 AM
  #279
snappster's Avatar
Default Begin
Let the games begin. Come to me Zen of motorcycle maintenance, come.
This being my first ever head and cylinder install my question is which of the two big gaskets is for the head?
Edit: I just plucked out of the crank case one of the two dowel pins that locate the cylinder on the cases, sitting pretty on the crank. That could have been bad juju.
Anything else that people accidentally drop in to the bottom end I should look out for? The pdf manual's pictures are pretty useless, does anyone remove the front chain guide?
I didn't have a copy of the manual in the garage so I winged it. I think I will print out the installation instructions though.
Attached Thumbnails What I/you did today on the bike-image-37-.jpeg
Old Jul 19, 2017 | 12:53 AM
  #280
s10gto's Avatar
The smaller one with the metal cylinder fire ring. Head gasket won't fit cylinder base anyways. Good luck!
