TAPP USB outlet install
Old May 16, 2012 | 08:41 PM
ahnh666's Avatar
the klx battery is 12 volts and 6ah...not sure how a usb works, but seems to draw power....even with just a usb socket plugged in (nothing plugged to the usb)...it seems to be drawing lot more power from the battery...i can see the battery tender immediately switch on to charge the battery...i would do what rgoers suggested to get a true answer if you are going to keep the usb charger on your moto...or, install a on/off switch...
Originally Posted by Brieninsac
The amount of current drawn when the TAPP is not in use is about 8mA. A typical motorcycle battery is rated at about 10Ah (amp-hours), or 10000 mAh. That means it would take about 1000 hours for the TAPP to drain your motorcycle battery or about a month.
ahnh666
Dec 20, 2011 03:36 AM
simon says
Feb 3, 2011 01:56 PM
first cruiser
Sep 21, 2009 11:40 PM
je2000
Oct 15, 2008 12:19 AM
quik6r
Mar 11, 2008 05:02 AM
