Suspension help for a novice
Old Dec 16, 2007 | 01:20 PM
niven's Avatar
Banned
Default RE: Suspension help for a novice
just jokinng son kickstart a 441 bsa when not doing triple jumps.
Old Dec 16, 2007 | 03:29 PM
Sid Post's Avatar
ORIGINAL: KLXer
The bottom screw is rebound. If you turned it max in you slowed rebound way down. Your rear end will stay compressed longer. You may experience packing because the shock cant recover fast enough between bumps.
For the top it is compression. If you turned it out 1 turn you made it softer.
Yes, I think that's where I'm at right now. I need to re-ride and verify my settings though. When the rebound was all the way out I basically had no suspension because it was bottomed out or close to it. One turn out is a little slow on the rebound but, okay for tar snakes on asphalt. Off road I will need to firm it up some if I do anything more then soft trail rides though.
Compression is a little softer as well and seems to help the ride on asphalt.
On asphalt I want to soften the initial impact jolt and stop the harsh kickback in the seat which is where I think I'm at right now. I will be riding carefully on these suspension settings until I get some confidence I won't get wheel hop, washouts, etc. due to my novice attempts "adjusting" my suspension.
Old Dec 16, 2007 | 03:32 PM
Sid Post's Avatar
Niven, you sound like a some kid on the play ground making fun of other kids due to your own insecurities.
Please go thread crap somewhere else.
cegusman
May 26, 2012 12:24 AM
Kiptanui
Ninja 250R
May 26, 2009 11:06 AM
slimenlyman
Feb 1, 2009 12:10 AM
cool change
Nov 15, 2007 01:43 AM
Zwild_m30
Mar 7, 2007 07:53 AM
