MAGNUM Dyno-Boost Motorcycle Performance Chip
Old Sep 4, 2013 | 06:20 PM
fantom's Avatar
Default MAGNUM Dyno-Boost Motorcycle Performance Chip
I wanted to ask if anyone uses or has tried this unit, the specific
would seem a good product.
# 15% + HP
# 15% + Torque
# 30% + acceleration
# 6% economy improvement
# Higher top end speed (if no factory speed governor or RPM limiter fitted)
# No flat spots
# Improved throttle response
# Engine reliability, durability not affected
# Power status LED
- MAGNUM Dyno-Boost Motorcycle Performance Chip
thanks
Old Sep 4, 2013 | 07:46 PM
Hey!...you save $91...it must work.
I'm taking it that you have an EFI model KLX?
Old Sep 4, 2013 | 08:03 PM
CousinLarry's Avatar
Waste of cash.. Snake oil.... Spend the money on a real mod(s).
Old Sep 4, 2013 | 08:48 PM
Do an extensive search and read a lot of the negative reports on this unit. Apparently they make a unit for outboard motors and a bunch of other stuff, and I got the impression that all it did was make the computer fatten the fuel delivery parameters by fooling it with different temperature inputs. It may have also done something to the timing in some cases, because many of them had to run the highest premium fuel to stop detonation. The comment most frequently noted was "snake oil" from what I saw. The "real" and respected fuel/computer programmers out there that I've seen actually have fuel and ignition maps specific to the individual bike...and cost more as a result.
Old Sep 5, 2013 | 02:52 AM
Klxster's Avatar
Just one might not do it - Wire in two of them and HANG ON !
Old Sep 5, 2013 | 04:09 AM
JoelThailand's Avatar
I spent a good few hours online researching this magnum product last year, I concluded "snake oil". There are zero positive reviews on real forums anywhere in the world to substantiate their claims!! Only lots of "customer" reviews that magnum use on their own website & they also sell on Amazon with their own positive BS reviews!!
Kawasaki D-Tracker X - MAGNUM REVOLUTION-PRO Motorcycle Speed / REV Limiter CDI Box
Shame, as i wanted a simple gadget to increase ignition timing on the EFi bike.
Don't bother with magnum folks!
Old Sep 5, 2013 | 10:53 AM
fantom's Avatar
Thanks for the answers, as I suspected this system is not worth the money they ask for.
Daves_636
Apr 16, 2007 06:55 AM
Grind
Feb 18, 2007 08:40 AM
Grind
Feb 17, 2007 10:04 PM
MAD KAW
Sep 15, 2005 11:45 PM
MAD KAW
Aug 17, 2005 01:25 PM
