Loving my KLX250SF w/carbs!
Old Feb 2, 2023 | 10:09 PM
  #41
bmart's Avatar
Can anyone confirm if new cables/hoses would be needed on an '09 SF? Thank you!
Plan to order soon. I wish that all of my bikes had 135mm grips like my old FJ. My big hands are so tight on these!
Old Apr 24, 2023 | 02:44 PM
  #42
bmart's Avatar
Has anyone fitted alternate fork caps to that sag was easily adjustable? I did this to my old CB-1 and it was a great, and cheap, addition. Thanks!
Old Mar 21, 2024 | 05:50 PM
  #43
bmart's Avatar
Hey all. QQ about suspension sag on the SF.
On my street and track bikes starting with rider sag (and proper spring rates) of front ~35mm and rear ~30mm.
Off road seems like 1/3 sag on rear and 15-20% sag on front.
I'm currently at 50mm on the front (should be ~35?) and 45mm on the rear (should be 68?) That seems like a dramatic change. Have I got it all wrong? Spring rates are pretty close for my weight.
Old Mar 25, 2024 | 10:45 PM
  #44
bmart's Avatar
No one has rider sag numbers to share? Please?
Old Apr 9, 2024 | 03:11 PM
  #45
bmart's Avatar
How about cold and hot tire pressure for "all pavement" SuperMoto work? I ran last weekend and just kept taking air out between sessions, but never had good grip on these S22 tires. Thanks!
Old Apr 9, 2024 | 06:00 PM
  #46
Tacoma660's Avatar
Shinko 705 I usually keep around 38 for fairly aggressive riding on the road. As for sag usually about a 1/3 front and back
Old Apr 9, 2024 | 06:11 PM
  #47
bmart's Avatar
Gotcha, thanks. I was running ~30 hot front and back (27 cold) and guys were suggesting down to 22 cold.
I'm running 25% rider sag in front and 33% in rear. The rear doesn't feel too bad (aside from sliding all over under throttle), but that front really moves a lot! lol
Old Apr 9, 2024 | 06:48 PM
  #48
Tacoma660's Avatar
I have racetech springs and gold valves desert settings front and rear makes a huge difference. Changing the fork oil every year might help to if you doing track days and probably shock oil every other year
Old Apr 9, 2024 | 09:34 PM
  #49
bmart's Avatar
May I ask your weight and the spring weight you went with on each end?
The stock rear is great for me. The front is a little light, but not much.
Hoping to dial it in enough to ride harder at the next SM day in a few weeks.
Old Apr 11, 2024 | 10:08 PM
  #50
bmart's Avatar
Well, I've written to most suspension places to see the options. RaceTech doesn't seem to have the springs that they recommend. While i'm waiting, I may shim these springs a little to try to stiffen things a bit without it completely sucking off road.
Akos Ferencz Nadas
ER 6N
Jan 29, 2023 03:38 PM
redandblack250
Apr 21, 2014 03:14 PM
bryantjt
Nov 18, 2007 03:31 PM
SERGE
Mar 1, 2006 05:52 AM
