just found oil leak need help
Old Jan 26, 2012 | 01:51 PM
durielk's Avatar
1. Wash your bike
2. Go for 5 mile ride.
3. Go over it with a paper towel until you find the oil. Follow the oil to the leak.
4. Replace the valve gasket or reinstall properly.
Old Jan 31, 2012 | 07:37 AM
lanky's Avatar
Originally Posted by durielk
1. Wash your bike
hey just did this and found the valve gasket is leaking in a number of places can see the oil ruining down it. had a poke of the gaskets in thoes two dipping down bits were some of the oil is coming from and they moved a little bit so gonna take bike apart tomorrow and tighten the valve cover and see if that does the trick. will up date then. bike is only an 08 so hopfuly wont have to change gasket cause it ant that old and shouldnt have to.
thanks
mike
Old Jan 31, 2012 | 01:06 PM
durielk's Avatar
Don't forget to apply an even bead of silcone sealant. My gasket is 5 yo and reinstalled fine.
Old Jan 31, 2012 | 01:25 PM
If you need silicone anywhere but the 2 "half moons" its not right. I would get a new gasket. I have taken mine apart many times and only used silicone right where the half moons meet the rest of the gasket. No leaky. Be careful tightening up the 3 valve cover bolts, its only going into aluminum. I always torque mine per the manual.
Old Jan 31, 2012 | 01:40 PM
You're correct. The only place for silicone gasket sealer on our valve cover gaskets is the half moons. You can often get away with applying silicone sealant all over the rubber gasket, but you really run a risk of that piece of rubber squeezing out of there like a banana peel.
From reading here on the forum, weren't there some '09 or later models with an undersized or defective rubber valve cover gasket?
Old Jan 31, 2012 | 01:44 PM
jeffzx9's Avatar
I might suggest some Permatex "the Right Stuff" sealer. THIN layer on the gasket; don't crap it up. Let it sit a couple hours before starting.
mikey113
Oct 12, 2024 02:54 AM
Demonrider
Mar 27, 2012 10:40 PM
Green hornet
Sep 16, 2011 02:10 AM
dmojave250
Jan 29, 2009 02:18 PM
FiveLiterRiceEater
Jun 26, 2007 01:48 AM
