Excessive Blow By?
Old Jan 6, 2020 | 10:39 PM
ForestThump's Avatar
Default Excessive Blow By?
Folks,
With the passing of 2019, I didn't get anywhere NEAR the amount of riding in that I had hoped. No worries, that tends to happen considering I have 3 youngsters whom I devote much of my free time. In fact, my youngest has developed a passion of riding motorcycles and now he's riding too - a TTR50. Score!
Anyway, a resolution for 2020 is to ride more. And though snow is currently flying in my neck of the woods, I find myself in the garage in the evenings tweaking and wrenching on the bike in anticipation of warmer temperatures.
I started it this past weekend (just to hear it's lovely sound). And while it was idling, I figured I'd take the oil fill cap off to check for blow by - not because I suspected any problems, only because - well, why not. I was actually shocked to discover how much blow there is. I was expecting very little, or maybe just a whisper of air. Instead, it was chugging out of there with force!
So, simple question: is this normal?
Engine runs perfectly, from what I can tell. Plenty of power, no misses, hesitations, or anything of that nature. Doesn't burn any oil. Gets a solid 70mpg average riding. A hair over 2000 miles.
Old Jan 7, 2020 | 02:23 PM
Very normal. Single cylinder engines with small crankcase volumes move lots of air while running. Crankcase pressure is an interesting topic even on multicylinder racing engines that operate at high rpm. Big singles like the KLR650 may even have a little bit of oil use because of this issue, but the KLX doesn't have a problem with it.
There's nothing wrong with you KLX unless you're actually seeing blue oil smoke coming out the exhaust, and even then it's more likely due to valve train oil seals or piston ring wear, not crankcase pressure.
Google a topic like crankcase pressure control in racing engines, and you'll see some interesting issues on the subject.
Old Jan 7, 2020 | 03:00 PM
Excellent feedback, thank you!
No smoke coming from the bike at all. This puts my mind at ease.
Thanks again.
qxangelxp
Jul 12, 2017 11:56 AM
bongoz
Jul 23, 2014 12:21 PM
nn04
Ninja 500R
Mar 8, 2009 11:02 AM
slow250r
Ninja 250R
May 31, 2008 01:03 PM
RubberxSidexDown
Ninja 500R
17
Oct 8, 2006 10:51 AM
