cs sprocket removal
Old Aug 9, 2007 | 05:41 PM
Davebert's Avatar
Default RE: cs sprocket removal
I had the same problem. I just ended up with my air hammer with a dull chisel and hit it once on the back side of the nut (larger part). Brrrrpp! Came right off with no damage.
Hope that helps,
db
Old Aug 10, 2007 | 01:14 AM
mudjunkie's Avatar
got r done...bought a 18-inch strongarm, 1 1/16 inch impact socket (6-point) and a can of liquid wrench..left the bike off the jack until I had the nut loosened..I think that helped some too..friend sat on bike, brake on and CRACK it finally came loose...took it for a ride on some tight trails, hills, roots, rocks, etc and loved it. really a big difference off road and as I read more power to accelerate up the hills..thanks guys for the advice
Old Aug 11, 2007 | 12:07 AM
mooredan's Avatar
OK, I think that my CS nut was probably on as tight as anyone could ever get it.
Actually, I have had the nut off before when I swapped the stock 14T for a 13T -- and I know that I torqued it back on to spec.
So now I want to go from a 13/42 setup to a 14/49 setup, so I'll put the stock 14T back on. Got the new rear 49T and a new chain and proceeded to take off the front nut. NO WAY. I tried everything:
- putting a 3/8" ratchet extension over the swingarm and through the rear sprocket -- ended up indenting the swing arm and bending the rear sprocket after using a six foot piece of conduit over a 18" 1/2" drive breaker bar
- went out an bought a 300 ft-lb capable electric impact wrench - didn't have a 6 pt. socket and ended up rattling much of the chrome plating off of the socket
- got a big buddy to sit on the bike, standing on the brake --ended up being able to overcome his weight and the brake with the 6 foot extension
Decided that I wasn't going to get it off the normal way. Remember that the nut has sort of a flange on the back side of it?
I figured that I could carefully cut off the flange with a cutting wheel on the dremel tool to relieve the pressure.
With that thought in mind, I ordered a new nut and washer because I'm going to destroy them.
I saw that the parts will arrive tomorrow, so proceeded with my surgery. It went suprisingly well and took only about 10-15 minutes to cut off the flange. I was really suprised that after doing this the nut spun by hand!
The photo shows that I cut the washer too, but I really didn't need to. I didn't hurt the output shaft or anything else.
Now how in the world did it get so tight?????
I have a theory. Some of you may remember my mudhole incident, where a rock got lodged in the rear chain guide and I ended up spinning my clutch.
https://www.kawasakiforums.com/m_141059/tm.htm
I figure that the while the wheel was locked up, the engine, with its full torque, tightened that nut up before moving on to and destroying the clutch.
Anyway I got it off now and will get the new gearing set up soon.
Old Aug 11, 2007 | 07:58 PM
mooredan's Avatar
More fallout from the mudhole event. While swapping the rear sprocket I discovered that the chain adjuster got mushed. Either this happened then or while I was trying to get the CS nut free. Note the deformed number 5 and circle cutout.
Old Aug 11, 2007 | 11:44 PM
gerrynolan's Avatar
Oh well, #6 looks pretty good. Got any room for tightening? Not a big difference between 5 & 6. Just don't go below 2 1/4" of slack.
Old Aug 12, 2007 | 12:08 AM
mooredan's Avatar
It's good enough right now. 60mm of slack. I'll include the adjuster on the next order to ronayers and replace it then (whenever that is)- nothing urgent for now.
Old Aug 12, 2007 | 08:31 AM
MaverickAus's Avatar
I couldn't get mine off even with an air gun, I took it to the dealer. I have tried since they put it back on and I still cant get it off [:@]
Old Aug 12, 2007 | 02:13 PM
Davebert's Avatar
I used one of these and it knocked the nut loose in 2 seconds. No damage. I tried with a 1/2 impact and breaker bar and wife holding brakes etc with no luck. You can get a cheap air hammer chisel.
Hope that helps,
db
Old Aug 13, 2007 | 12:26 AM
mudjunkie's Avatar
mooredan,
just curious, but is the tire still running true with the damaged adjuster?..something Iwould keep an eye on
Old Aug 13, 2007 | 12:56 AM
mooredan's Avatar
Yeah, I thought about that too.
I measuredthe runoutwith a dial guage and found it to be around 0.040" (~ 1.0mm). The standard is a runout of 0.8mm (0.031") with a service limit of 2.0mm (0.078").
Thanks for the QA check. (Quality Assurance)
cyrjordan3
Sep 25, 2009 04:51 AM
The Mekon
Jan 5, 2008 11:24 AM
chris72a
Dec 12, 2007 09:25 AM
Davebert
Jul 21, 2007 01:58 PM
Jun 11, 2007 05:11 AM
