cs sprocket removal- question
Old Apr 29, 2006 | 02:32 AM
bmwhd's Avatar
Default RE: cs sprocket removal- question
ORIGINAL: Iowaguy
I'm trying to remove my cs sprocket, and never done this before. Is it threaded backward or is it just tight? How have you guys broken it loose? Thanks.
It is very, very tight but not reverse threaded!
Here's the dope: Get a wooden broom handle or piece of 1x2 and insert it into the rear sprocket over the swing arm This will allow the chain to hold the sprocket still while you lossen the nut. Put a LONG breaker bar on you socket or get an impact wrench.
Another trick that can work if you don't have a breaker bar is to take one of those big orange pipe wrenches and place the jaws over the end of your standard rachet handle to increase the length.
Old Apr 30, 2006 | 03:14 AM
onestarr99's Avatar
My front sprocket was so tight I had to use a little heat on the nut with an impact gun to get it loose.I do not recommend using heat because too much and you could warp something and there is a rubber seal on that shaft!
Old Apr 30, 2006 | 03:59 AM
KAWASAKIspeed's Avatar
Yeah my dad has done this he used a impact on his becasue it was tight.
Old Apr 30, 2006 | 12:54 PM
MaverickAus's Avatar
You could steal a harley toolkit .... half a brick and a cold chisel
[8D]
Old May 1, 2006 | 12:17 AM
motoguy128's Avatar
buy a $50 electric impact wrench and save yourself lots of trouble. THe impact wrench also works great for the rear axle, clutch removal, and with chain breaking tools.
Old May 1, 2006 | 05:26 PM
bmwhd's Avatar
ORIGINAL: Iowaguy
well, none of those hints seemed to help and i won't do the heat thing. the stock sprocket will not accept a 1" anything as the holes aren't that big. a socket ratchet isn't long enough. i think i'll have someone heavy sit on it with the rear brake on on rough concrete and use a breaker bar.
Did you stick the 1" broom handle through the REAR sprocket? That's what I was suggesting. The broom andle keeps the rear sprocket (and thus the chain) from moving while you jump up and down on the rachet handle attached to the FRONT sprocket nut. Also, sorry to be asking dumb questions but you did hammer the locking ring flat first, right?
Old May 1, 2006 | 08:25 PM
bmwhd's Avatar
ORIGINAL: Iowaguy
ORIGINAL: bmwhd
ORIGINAL: Iowaguy
no. i did try and stick the broom handle thru the sprocket but the oem sprocket's holes are not large enough to accommodate a 1" broom handle. i did see that ring but didn't realize i needed to hammer it flat. i'll try that. thanks again. i'm a dumba$$.
Oh. That explains it then. And don't worry, it might be that there's at least one other person on the planet that's forgotten that locking ring... [&:]
