Big gun jetting
Old 05-08-2007, 04:31 PM
tremor38's Avatar
Default RE: Big gun jetting
+1 on that. Thatis a CYA statement on BG's partto make sure you don't start out too lean. Also, a Dyno Jet #145 might equate to a Keihin (OEM) #140, or vice versa. The jets differ slightlyinsize, which equates to their inner surface area. Also, the size difference is not linear so there will be some 'hit-n-miss,' depending upon which brand of jet you use.
ORIGINAL: Dragone#19
That may be a generalized starting point for your elevation that you run a #145 main only trip. All of the#'s listed here from members at their altitudesand mods are prolly theirpreferredsetup.But it is up to you to find the setting that is right for your set up. Members listing pilot sizes, mains and needles along with position of the clip and including the altitude plus using any other mods tells me that they know something about carburation.
EL Brandon
02-23-2010 09:22 PM
joker7337
05-02-2006 01:46 AM
klxstiffler
04-27-2006 02:52 AM
JazZ023
04-13-2006 04:22 AM
JazZ023
04-05-2006 03:26 PM
Quick Reply: Big gun jetting
