Big Gun Exhaust Evo X/ Dyno Jet Kit
Old May 1, 2006 | 09:34 PM
joker7337's Avatar
Default Big Gun Exhaust Evo X/ Dyno Jet Kit
Hey everyone- I have just successfully installed the Evo X big gun to my bike. First off the sound is great- performance is much better too. Overall I am getting her up to 86-88mph from 75mph with the stock exhaust. I also bought the Dyno-Jet kit but have yet to install it. I guess my questions are- 1. As long as I am getting good performance is there still a need to install the jet kit.
2. Will installing the Jet Kit get me even more performance. 3. Obviosly installing the jet will void my warranty- so I am guessing I should wait until the warranty is up to make any changes...?
Old May 1, 2006 | 11:12 PM
Marty's Avatar
Default RE: Big Gun Exhaust Evo X/ Dyno Jet Kit
Not necessarily!
The carb mod is reversible. If you have a problem, just take out the jet kit and exhaust prior to taking the bike in for service.
BTW, they might consider the exhaust a mod too!
Depends on YOUR dealer.
Old May 1, 2006 | 11:13 PM
onestarr99's Avatar
Call your local dealer and ask them if it will void your warranty. I asked mine if I install a pipe and jet the carb will it void the warranty and he said no.But don't take my word for it ask them. Stuff like that varys from dealer to dealer sometimes so I would ask them. I know that it should be all the same at all kawasaki dealers but some dealer let somethings slide and some don't!!!
Old May 1, 2006 | 11:37 PM
bmwhd's Avatar
ORIGINAL: joker7337
I would HIGHLY recommend you install the kit. You'll be amazed at the difference over what you have already seen with the Big Gun. Keep in mind, that even though the stock airbox is very restricted, you may be running a bit more lean with the Big Gun simply because it flows more air out. If the engine is able to suck more in, you're going to be leaner than stock. Since the bike is VERY lean from the factory, you may make a bad situation slightly worse with just the exhaust.
Old May 2, 2006 | 01:46 AM
klxstiffler's Avatar
SWEETT MINE SHOULD BE HERE TOMMORROW
ColoradoKrug
Nov 1, 2017 09:20 PM
leisman7
Apr 23, 2009 01:19 AM
buffalony
Sep 12, 2008 01:18 AM
YYY.GUY
Aug 29, 2006 08:32 AM
klxstiffler
Apr 27, 2006 02:52 AM
