Another 2009 leaky valve cover gasket
Old Apr 15, 2014 | 02:59 AM
cmott426's Avatar
I got pissed and super glued it the valve cover. Just enough to make it stay in the grooves to get it installed. No leaks. RTV on the half moons
Old Apr 15, 2014 | 12:29 PM
wildcard's Avatar
Originally Posted by 2veedubs
Not strange at all yours is a 2012. 09s may have had Malaysian gaskets? My replacement says made in Japan! The 09s had a shrinkage issue, possibly due to poor material quality. My buddy has no issues with his 07. Consider yourself lucky.
+1 if you have anything but an 09, you probably won't have problem.
Old Apr 15, 2014 | 12:35 PM
hounderd's Avatar
How I feel about owning an 09 and this being completely true;
Old Apr 15, 2014 | 02:25 PM
Lotrat's Avatar
My 2009 leaked... nowhere near as bad as an old vw. I let it go until I checked the valves at 7000 miles. Valves were in spec and no more leaks. It's a tight fit even with the tank off. You want to make sure it's on right before snugging up the valve cover so you don't pinch it. 800 miles and no leaks.
Old Apr 15, 2014 | 02:26 PM
RockabillSlapMatt's Avatar
I pinched mine after big bore kit, thought my gaskets were faulty because my motor was covered in oil. Pinched it right at the front of the motor where you can't see it.
Old Apr 16, 2014 | 06:57 AM
Sharan's Avatar
Replaced the gasket yesterday. No need to guess the year of manufacture
bschoolz1
Jun 19, 2012 06:49 PM
scotty7676
Sep 30, 2009 02:08 AM
je2000
Nov 9, 2008 05:10 PM
preemo_21
Apr 17, 2008 08:25 AM
FiveOMaster
Aug 29, 2006 08:04 PM
