Another '09 with valve cover gasket leak
Old Sep 30, 2009 | 01:39 AM
scotty7676's Avatar
Default Another '09 with valve cover gasket leak
Just bought a used '09 and noticed oil leaking from the valve cover right where the front "half-circle" is on the right side. Went ahead and ordered a new one (out of warranty) and will replace soon. For now I took it off and globbed a bunch of Liquid Gasket 1104 on it (same as yamabond) and put it back together, which was a chore trying to get the damn thing back in place because it shrunk! After reading up a bit, looks like I should have followed directions and put a thin layer of liquid gasket instead of two thick layers (to try and hold it in place while assembling). Oh well, hopefully not too much squished out inside the motor . Couple good rides and no leaks yet, guess when I replace it I'll see what a mess I made. Probably change the oil and filter and hope it caught most of the gunk.
Enjoy!
Old Sep 30, 2009 | 01:54 AM
CousinLarry's Avatar
Be careful putting too much of that on - especially up there.. It spreads out a lot when you torque the cover down - that dries (or doesn't depending on how long you waited)...
You don't want big globs of that stuff floating around...
Old Sep 30, 2009 | 02:03 AM
scotty7676's Avatar
Yeah, unfortuntly it's too late now. I'll be curious to see what comes out when I drain the oil.
Old Sep 30, 2009 | 02:08 AM
95451's Avatar
Welcome To K.F.
Do Keep Us Up-Dated
oldgypsy
Apr 16, 2014 06:57 AM
higgs
Jun 1, 2012 10:37 PM
je2000
Nov 9, 2008 05:10 PM
preemo_21
Apr 17, 2008 08:25 AM
FiveOMaster
Aug 29, 2006 08:04 PM
