Valve Cover Gasket Problem??
Old Aug 28, 2006 | 02:43 AM
FiveOMaster's Avatar
Default Valve Cover Gasket Problem??
I took all the EGR stuff off my KLX250 and capped the port on the engine and now it is building pressure in the head and popping the tabs on the gasket out. I put all the EGR stuff back on and it is still doing it. Anyone have any ideas?
Old Aug 29, 2006 | 01:40 AM
bryantjt's Avatar
Default RE: Valve Cover Gasket Problem??
You didn't by chance plug the crank case breather thats on the right side of the engine did you?
Old Aug 29, 2006 | 01:41 AM
I was just wondering that.
Old Aug 29, 2006 | 02:12 AM
Bad Bear's Avatar
Yes it has to be a plugged Crank Case Breather doing the smog mod will not cause that problem
Old Aug 29, 2006 | 08:04 PM
Hey guys thatnks for all the responses. It was the crank breather that was plugged.
scotty7676
Sep 30, 2009 02:08 AM
hoedogg
Jan 13, 2009 02:10 PM
je2000
Dec 7, 2008 02:30 AM
je2000
Nov 9, 2008 05:10 PM
preemo_21
Apr 17, 2008 08:25 AM
