MOOSE 13-tooth front sprocket
Old Apr 15, 2006 | 03:39 PM
Marty's Avatar
Default RE: MOOSE 13-tooth front sprocket
Iowaguy,
Thanks a whole bunch for the link! Seems like there is NO ONE that has 13 tooth sprockets in stock.
The best part is that there is an application chart there:
Part 8401213 fits the following machines:
Kawasaki - KLX250S 2006
Kawasaki - KLX300R 2003
Kawasaki - KLX300R 2004
Kawasaki - KX450F 2006
Yamaha - YFZ450 2004
Yamaha - YFZ450 2005
Yamaha - YFZ450 2006
Yamaha - YFZ450 Bill Ballance Edition 2006
Yamaha - YFZ450LE Limited Edition 2004
Yamaha - YFZ450LE Limited Edition 2005
Yamaha - YFZ450SE Special Edition 2005
that shows all the applications that sprocket will fit.
Old Apr 16, 2006 | 12:03 AM
MaverickAus's Avatar
It also says there is only 2 sprockets in stock [8D]
Old Apr 16, 2006 | 03:09 AM
Not from Australia I didn't
Old Apr 16, 2006 | 05:09 AM
bmwhd's Avatar
Marty,
Have you tried having your various online sources look up Sprocket Specialists 514XK-13 or 564-13? Either will work.
Old Apr 16, 2006 | 05:11 AM
bmwhd's Avatar
I'm a little concerned that they list the KLX300R on this list as the sprockets are not interchangble.
ORIGINAL: Marty
Iowaguy,
Old Apr 16, 2006 | 05:35 AM
Spot on Todd, The 2006 and 2003 KLX300 use the same part number which as we know is different from the KLX250
Old Apr 16, 2006 | 07:39 PM
justin's Avatar
Hey so are you guys 100% this sprocket won't fit? I have to already get some things from dennis kirk so I was going to go ahead and get the sprocket aswell.
Old Apr 16, 2006 | 09:43 PM
bmwhd's Avatar
ORIGINAL: justin
No. But it is a concern that they list the two bikes together. It's got to be one or the other, not both.
