2000 ZX9R loss of power
Old 05-16-2007, 04:21 PM
zx9rfordrag's Avatar
Default 2000 ZX9R loss of power
I have a 2000 ZX9R and it has started lossing power. some addon's tothe bike are Full Muzzy exhaust, Stage1 dynojet kit, and K&N air filter.
The bike is street driven but used alot for Drag Racing. Last year the bike ran some 10.40's around 138 mph in the 1/4 but this year cannot seem to run in the 10's at alland is barely hitting 130 mph. I am not familiar with the carbs to go playing with things. Any suggestions on where to start?
Old 05-17-2007, 03:35 AM
Default RE: 2000 ZX9R loss of power
What does your leak down numbers look like?
Old 05-19-2007, 01:59 AM
I will check them and get back to you
Old 05-19-2007, 04:02 AM
hicktown's Avatar
leak down?
Old 05-20-2007, 12:35 AM
ORIGINAL: hicktown
leak down?
Yes a leak down, similar to a compression test but any leaks will be noted on your gauges to see if the pistons/rings, valves or even a cracked cylinder or gasket is causing issues. It is not fool proof, but before tearing into an engine looking for issues, it is nice to see what cylinder is causing the low pressure. Plus a leak down is cheap to do. It is just a troubleshooting tool that I like to use.
kmacloud
12-30-2012 07:38 PM
OLDHAT
12-24-2007 07:14 PM
dcorlando
02-14-2007 04:09 PM
lyle147
09-22-2006 11:14 PM
jman7680
06-08-2006 08:47 AM
Quick Reply: 2000 ZX9R loss of power
