94 Zx7 - Rough Idle after oil change and plugs
Old Mar 26, 2008 | 03:31 AM
Smorphine's Avatar
Default 94 Zx7 - Rough Idle after oil change and plugs
Can't figure it out. I changed the oil, changed the plugs and put it all together. Bike starts great but after a few minutes it starts to run rough and dies. Will restart with a bit of throttle but dies. Also, the bike is hard to shift into gear from neutral.
Tried running down all the vacuum lines, inspected the fuel filter, all seems good. Any ideas?
Old Mar 26, 2008 | 01:51 PM
Kohburn's Avatar
Default RE: 94 Zx7 - Rough Idle after oil change and plugs
most likely its the plugs - what kind did you get and did you check the gap to make sure it was correct before installing them?
when a problem starts its usually because of the last thing you did.
Old Mar 26, 2008 | 06:06 PM
ditto^^^ i would check the plugs too. is the fuel tank full? sorry for the dumb questiontry switching to reserve.
Old Mar 26, 2008 | 07:44 PM
stone_sour09's Avatar
+1hd
Old Mar 26, 2008 | 11:11 PM
Smorphine's Avatar
Thanks everyone for the quick replies. Will do. Does anyone know what plugs suppose to go in it? What gap?
Old Mar 27, 2008 | 12:14 AM
I'm thinking the plugs should be NGK CR9E or if you get the iridium it would just be CR9EIX
Old Mar 27, 2008 | 12:38 PM
Smorphine's Avatar
Should they come pre-gapped from the box or do I need to gap them? What gap?
Thanks again.
Old Mar 27, 2008 | 03:43 PM
Kohburn's Avatar
even the ones that claim to be pregapped tend to be off from bouncing around inside the boxes during shipping. pick up a haynes manual (usually 11-13$) it should have the gap info along with other useful maintanance stuff
Old Mar 31, 2008 | 02:50 AM
Smorphine's Avatar
Excellent advice. The plugs were the wrong type. Got them changed and gapped. The factory gap was a bit tight, had to open them a bit.
Thanks everyone.
adinoo
Ninja ZX-9R
13
Jun 13, 2013 02:12 AM
seizetheday4eva
Aug 14, 2012 04:25 AM
capncalyx
Aug 13, 2007 06:45 PM
slablocal
Jul 8, 2006 08:21 AM
