Rear brake barely holding
Old Jun 25, 2007 | 11:41 PM
KawiZX6R2006's Avatar
Default Rear brake barely holding
Hey guys, I don't know how long this has been doing this but my rear brake is hardly holding. The only thing stopping my bike is the front brake. I bought the bike new in Mayand it is a 2006 Kawi zx6r. I can push all I want on the brake lever but I can still push my bike out of a rest. Any suggestions?
Old Jun 26, 2007 | 12:33 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: Rear brake barely holding
bleed the rear brake and itll be fine.
Old Jun 26, 2007 | 02:19 AM
Or just change out the fluid and bleed it again.
Old Jun 27, 2007 | 07:51 PM
Sunrider's Avatar
i have the same problem, have checked with other 06 636 owners it seem like it maybe just the 06 636 trible??? brakes sucked right off the show room floor. took it back and they bleed the brakes, no change, i put braded lines on and bleed the **** out of them, no change, sanded down the pads and bleed them again with the caliper off so no air bubbles could be traped, no change, replaced the pads last nite, no change. this really sucks you can't even lock up the rear tire, the service dept here sucks i will try another one today and see if they have any idea's
Old Jun 27, 2007 | 10:40 PM
ya i have the tribal edition too. I called the service dept and told them the brakes need to be bled. I live in an apartment so no place around to do it on my own. Anyway, I have an appt to go get it looked at tomorrow.
Old Jun 28, 2007 | 02:13 AM
speedracer138's Avatar
There might be air trapped in the lines or in the master cylinder. It is very close to the exhaust midpipe and could be getting hot, boiling and causing air bubbles. Remove the rear caliper, put a piece of wood or material between the pads the same thickness as the rotor, raise it up in the air as high as you can, the try bleeding it. Make sure the leed screw is at the highest point. Tap the brake lines with something as you bleed it.
Old Jun 28, 2007 | 05:30 AM
Sunrider's Avatar
i took the master cyl apart cleaned out everything removed caliper bleed the crap out of it works ok now thanks for the info next time you are in honolulu we ride ya
Old Jun 28, 2007 | 05:52 AM
Daves_636's Avatar
my bike comes with rear brakes?!!!! sweet! lol just kidding.
mine likes to leave a little fluid now and then. i see a dollup on top of my rez cover once in a while.
Western NC
Apr 29, 2013 07:37 PM
djchan
Jul 4, 2012 11:16 PM
ericzitel
KX125
Aug 27, 2007 03:53 PM
DirtySouth636
Apr 4, 2006 03:26 PM
flyboy110b
Mar 24, 2006 07:07 PM
