Dealership setup
Old Aug 31, 2007 | 06:17 AM
Daves_636's Avatar
Default Dealership setup
hey...just to warn those who might have the same things happen to them... after wrenching a little on my bike i am starting to notice a pattern in it's setup that others may want to watch for. i am not 100% if the dealer assembles a lot of the accesories and bolts on our bikes but...i noticed
1) a lot of bolts arent torqued properly
2) items using(calipers) multiple bolts to fasten it in position dont all have lock tight on them. just one bolt has lock tight.
i was horrified not catch a few bolts, like my caliper bolts, loose enough to untighten by hand. one bolt was tightend with locktight. the other was almost dangling. blew my mind.
i am going to check the torque of every important bolt within reach. i've lost a few of them already. i mean...damn! come on!
Old Aug 31, 2007 | 11:28 AM
PittZX636247's Avatar
Default RE: Dealership setup
Thanks for the info about the bolts, some of use just take it for granted that everything is set up properly but thats the stealership for ya.
Old Aug 31, 2007 | 03:04 PM
when i bought my bike i did'nt notice till i got home thatthe bolt was missing from my side cover[>:]after that i went thru it also looking for loose bolts.
Old Aug 31, 2007 | 04:22 PM
aszrael1266's Avatar
The Dude
A friend had his tires mounted the wrong way on his bike
Old Aug 31, 2007 | 06:22 PM
hahaha, I have had the tires mounted wrong, had a loose front axle, and missing bolts. All from new rides from the Dealer! Different Dealers too!
Old Aug 31, 2007 | 09:18 PM
speedracer138's Avatar
I guess that is why the manufacturers cover themselves by stating: "check for loose bolts & hardware" during the periodic maintenance & inspections. It's a good practice anyway since vibration can loosen nuts & bolts. I always look the bike over before a long or hard ride. Also when you wash & clean your bike, check the nuts & bolts.
Old Aug 31, 2007 | 11:54 PM
Plus getting the service manual so that these simple checks can be done.
P2Z
Mar 25, 2008 01:49 PM
Kawirider09
Mar 21, 2008 05:08 AM
Nino18T
Jul 19, 2007 06:55 PM
TreySmokez
Ninja 250R
Jan 20, 2007 06:52 AM
markmeinteil
Nov 14, 2006 07:14 PM
