Newbie with dead bike
Old Nov 6, 2012 | 04:37 PM
nab101eg's Avatar
Default Newbie with dead bike
I have an '04 Ninja 500. I accidentally left the key on after hitting the kill switch and drained the battery. I tried charging the battery and the bike still wouldnt turn over at all - zero. Battery did test bad so I got a brand new battery and unfortunately got the same result - bike does nothing. New battery tests fine - so doesnt appear to be a lemon battery. Any advice on what else to check? THANKS!!!!
Old Nov 6, 2012 | 04:58 PM
Fuses?
Old Nov 6, 2012 | 07:25 PM
jeffzx9's Avatar
Welcome Nab. I'm assuming the bike was running before. Kill switch in the "run" position? Double-check your wiring, and as mentioned^ check fuses. Sometimes the key switches can get "wiggly," too; not make good contact.
Keep at it, let us know.
Welcome, again.
Old Nov 6, 2012 | 07:30 PM
Ya, I hate taking the bike apart to check fuses and find I have the kill switch in!
Old Nov 8, 2012 | 12:15 AM
As mentioned above....double check your battery connections, make sure that your kill switch is in the proper location. Welcome to KF and congrats on the lil ninja. I enjoy riding an 05 model most of the time. lol
Old Nov 8, 2012 | 04:09 PM
nab101eg's Avatar
Thanks for the pointers. I had replaced the main 30 amp fuse; however, when I went back through everything, I replaced it again and all is good. Apparently, the first fuse I put in was bad - it didnt show as blown...but sure didnt work. Other than buying a battery that may not have been necessary yet, all is good. THANKS again.
Old Nov 8, 2012 | 04:44 PM
Welcome to the forums. That's exactly why I have never used the kill switch on any of my bikes. Glad you got it figured out.
CALISAKI
Jan 4, 2008 01:06 AM
jbatty308
Mar 24, 2007 04:06 AM
Snal
Mar 4, 2007 08:53 AM
Nobrakes
Jun 28, 2006 07:00 PM
cdm369
May 16, 2006 04:09 AM
