Need a good switched hot.
Old Oct 17, 2006 | 04:11 AM
GoldenVelvet's Avatar
Default Need a good switched hot.
Hi this is my first post so be gentle!
I'm hooking up an accessory gauge to my 06 Ninja 500. Well its not so much a accessory gauge as it is a clock. Anyways. I am taking my constant hot straight off the battery (unless someone knows a better one?) I need a switched hot for the gauge. Anyone have a wiring diagram laying around?
Old Oct 17, 2006 | 06:03 PM
Notstock's Avatar
Default RE: Need a good switched hot.
You need to find your ignition, 12 volts when you turn on your key. I have no diagram but its easy if you have a multi meter.
Old Oct 18, 2006 | 07:50 AM
NS, sounds like he is installing a clock which takes consistant juice.
Old Oct 18, 2006 | 09:18 AM
The clock takes both. A constant hot so it will keep the time, and a switched hot that will make the display and back lighting come on.
I'm taking the constant hot direct from the battery and I was really hoping someone would have a wiring schematic so I didn't have to hunt for a witched hot.
Old Oct 19, 2006 | 04:22 AM
That makes sense now to me, lol
No schematic here either. Use your test light.
Old Oct 19, 2006 | 06:21 AM
BigRig18Wheeler's Avatar
Welcome to the forums...
I can't help you on a schematic either..... But wouldn't a battery operated $10 clock be easier?
Old Oct 19, 2006 | 07:21 AM
Its more then just a clock but calling it a clock its the easyest way to think about it.
Old Oct 19, 2006 | 07:34 AM
ORIGINAL: Dragone#19
Think about it this way. When you shut off your car your stereo doesn't lose its pre-set stations and the clock doesnt reset its self but you cant turn on the radio with out the key.
The switched hot is the key on/off and the constant hot is what retains the pre-sets stations and clock keeps the clock from resetting its self.
The switched hot is what lets you actively turn the radio on/off.
Did that explain it?
Old Oct 19, 2006 | 03:20 PM
allan4169's Avatar
A switched hot would be the head light wire for the low beam, but you would loose that on high beam so how about the running lights on the front indicators.
crf230
Apr 30, 2009 01:32 PM
aszrael1266
Jun 19, 2007 03:37 AM
toad1025
Ninja 650R
Apr 13, 2007 12:54 AM
kwninja88
Aug 22, 2006 12:59 PM
murphmaster5
Apr 26, 2006 07:55 AM
