How hot is to hot
How hot is to hot
Hay guys with the worm weather im starting to look at my temp gauge a little more just wondering if theres a certain temp that i should pull over and let her cool i usualy see like 223 is that usual and what will i see in heavy traffic thanks.
RE: How hot is to hot
There are coolant additives you can put in to lower the temperatures a little, but sitting in traffic is when it'll get the hottest. Try to keep moving to get more airflow. I just got my header's ceramic coated to keep the engine a little cooler for heat radiating from the exhaust. I have also heard of people switching the plastic fans to metal/ Aluminum fans. I will find out more info about this and post it.
I had the same question when i got my bike and i called the dealer. the fan should come on at aorund that temp and it shouldnt get much hotter. if im siting in traffic it will usually go up into the low 120's then the fan will kick on and go donw into the teens.
