i just bought a 94 kx 125 need help!!
Old Apr 16, 2007 | 03:59 AM
zack_chase50's Avatar
Default i just bought a 94 kx 125 need help!!
the top end needs rebuilding and i need to know how i can tell the differnce between (A) cylinder or (B) cylinder does it matter
Old Apr 16, 2007 | 04:45 AM
Default RE: i just bought a 94 kx 125 need help!!
come on guys i need the help im about to start tearing it down and i need to know hwich i need to buy
Old Aug 5, 2007 | 05:55 AM
gouchie20's Avatar
Not sure what your question is. In order to check the condition of the cylinder you have to pull it off. Why are you condeming the top end? In order to check it besides visually looking for abnormalities is to measure it. You need an accurate way to check both the piston and the cylinder itself. Or take it to the dealer and them do it. Hope this helped
Old Aug 6, 2007 | 05:34 AM
What was the leak down test numbers?
Old Aug 27, 2007 | 04:12 PM
kx slaughter king's Avatar
to answer your first question, no. as long as it was made for this bike type it dosent matter wich one you use. if one has a substantuilly larger price tag then the other it is proabilly sompething special like a high compression head or sompething for use with high octane aolchol or another race fuel. either way you should be fine with either a or b. why are you replacing it?
Old Jan 12, 2008 | 10:22 PM
i found out! cylinder-a can be bored to a 135 and cylinder-b can be bored to either a 144 or a 150 (depends on the make and the year) if you plan to bore the bike then pay attn to that, it could help later.
BriansZ
May 19, 2009 07:08 PM
twatkins05
Jul 7, 2008 04:33 AM
howdydee2003
Ninja 250R
15
Feb 9, 2008 03:15 PM
Gmanigio
Jul 16, 2007 03:51 PM
CopperNiner
May 2, 2006 08:15 PM
