2022 KLR 300 Advice to best uncork this bike
Old Mar 25, 2023 | 07:16 PM
Skihobo's Avatar
Thumbs up 2022 KLR 300 Advice to best uncork this bike
I have a brand new 2022 KLR 300 and I need guidance to best uncork and get the best performance. What slip on would you recommend and do I need to remap the software and open the air box? Any links you could share would also help. I have never done this, so you got a newbie here. Big thanks in advance for your help. Thumbs up
Old Mar 26, 2023 | 02:30 AM
you might also post in the KLX250 forum too. Lots of overlap here.
First I'd take a look at the intake snorkel and if it is the smaller KLX version, get the KDX200 snorkel. It is quite literally twice the cross sectional area and a bit shorter in the air box. Better air flow. That will likely boost your power the most. I am not an owner of an EFI KLX, so I am not totally up on them. I do know there is a second butterfly in the intake that can be removed to boost power too. Cross post in the 250 forum as well as the 300 R.
Old Mar 28, 2023 | 07:00 PM
Skihobo's Avatar
Default Thanks for the feedback
Thanks for the feedback, I will search for larger snorkel, this make great sense. It's the EFI that has me stumped too, so I am going to hold off on purchasing a slip on pipe until someone can give me good advice on the mapping.
Old Mar 30, 2023 | 10:02 PM
tooter's Avatar
I run a snorkel...
...as well as a slip on pipe and larger diameter chambered header.
As long as the ECU is operating in closed loop, the O2 sensor will provide the necessary information to keep the proper air/fuel ratio. Because I use my KLX for regular daily transportation, it always runs in closed loop and so there's no need for a tuner.
Old Jun 17, 2024 | 05:39 PM
EdKY's Avatar
Default Snorkel
Originally Posted by tooter
I run a snorkel...
Really enjoy my 300SM. Tried removing the stock snorkel. Didn't seem to run better. Tooter: What snorkel did you use to replace the stock one?
Old Jun 17, 2024 | 08:49 PM
tooter's Avatar
It's the Factory KDX200 snorkel like everyone else runs.
mikey113
Oct 2, 2012 09:56 PM
Hound1
Aug 29, 2012 02:03 AM
Hound1
KLR650
Aug 28, 2012 09:02 PM
Cropduster21
Nov 28, 2007 04:36 PM
Bert007
KLR250
Oct 1, 2007 10:49 PM
