Where to get cam chain?
Old 07-09-2010, 04:15 PM
CousinLarry's Avatar
Default Where to get cam chain?
To the people who have replaced their cam chains - where did you get them? All I can find are $80 OEM ones.. Does any aftermarket company make them for our bike? Or are we stuck with OEM?
I can't find anything else...
Thanks
Old 07-09-2010, 04:26 PM
TNC is offline
Yeah, got an OEM one for mine. I agree, it's pricey. Thankfully the shop I used to work at for 15 years still gives me the employee deal. I notice in the Tucker/Rocky catalog that there are lots of aftermarket cam chains, but most are listed by chain plate/roller size and pin numbers. I didn't study the spec on our KLX chains to compare, but maybe it's worth a look.
BTW, Mark at Kreiger Tensioners is sending me the KLX manual cam chain tensioner prototype next week to try.
Old 07-09-2010, 06:38 PM
wild will's Avatar
What will be the advantage of a manual tensioner compared to the stock one, just curious?
Old 07-09-2010, 06:47 PM
wild will's Avatar
http://cyclewareables.com/pages/cam_...ns_by_size.htm
If you scroll down they have the same model 92RH2010 chain that matches the stock one, just need to find how many links?
The 07 cam chain #92057-1416 says 92RH2010 next to it?
Old 07-10-2010, 12:14 AM
TNC is offline
Will, the reason some of us are replacing cam chains on relatively low mileage motors is because the factory automatic cam chain tensioner in some instances is not maintaining proper tension. Kreiger has made tensioners for different bikes with this issue, and he's making one for the KLX.
Old 07-10-2010, 03:34 PM
wild will's Avatar
Thanks for the info, good luck and let us know how it works.
Old 07-10-2010, 04:16 PM
OEM it is.. And let me know when the manual tensioner is working!
Old 07-10-2010, 07:52 PM
TNC is offline
Hopefully I'll have it to post pics of next week and install it immediately. I'd like to have it checked out for my Colorado trip next month. You know...for us old enough to remember, manual cam chain adjusters were the norm in the not-too-distant past. My '73 Z-1 900 had one, and it was easy to adjust...as well as several other bikes I had. I know one thing...I never had to replace a cam chain at 11,000 miles on anything I owned with a manual adjuster.
SDRRider
07-06-2006 09:00 PM
2weelz
07-03-2006 09:41 AM
2weelz
06-24-2006 07:25 PM
50 Slider
05-30-2006 02:27 PM
kawi636freak
05-18-2006 03:36 AM
Quick Reply: Where to get cam chain?
