When to have valves adjusted?
Old Oct 24, 2007 | 08:30 PM
DC4500's Avatar
Default When to have valves adjusted?
So at what mileage arepeople finding that their valves need adjustment. I know that the owners manual says it's at 7500 miles but I just turned 2000 and am getting quite a bit of racket from the motor. I believe it's the valves. It sounds like the '68 camaro I use to have when its lifters went bad. It's like a fluttering/ticking noise that fluctuates with rmps.
Old Oct 24, 2007 | 08:42 PM
KLXer's Avatar
Default RE: When to have valves adjusted?
I checked mine at 1100 when I went big bore & they were all ok.
Old Oct 24, 2007 | 08:50 PM
vfrpilot's Avatar
Same here, checked at 1000 miles and they were perfect.
Old Oct 24, 2007 | 08:53 PM
Kawi Wawi's Avatar
Mine were a little tight at 1200 kms. Probably they were tight when they left the factory.
In my opinion, 7500 is waaay too long to wait.
The noise is probably not valves tho - it's a noisy motor - timing chain mostly, but the entire top end is noisy.
You'll probably find your valves aren't far off spec - if any.
KDXmike
Sep 4, 2009 03:51 PM
LordVngr
Feb 14, 2008 10:23 PM
thecount
Jun 9, 2006 08:42 AM
quiklilrex
Aug 22, 2005 10:10 PM
ntence
May 24, 2005 12:33 AM
