is this suppose to look like this?
Old Feb 18, 2018 | 11:51 AM
peabrain's Avatar
i think mine is using to much oil........using a bottle a week on 2 tanks of gas
Old Feb 20, 2018 | 02:43 PM
horror_fan's Avatar
Originally Posted by klx678
Works with a two stroke running about 3-4 ounces of oil in the gas burned. Four shot glasses full. That little bit of oil won't hurt anything.
There can be only two sources, the air filter oil and the breather. As long as you haven't overfilled the crank case the breather wouldn't be a big deal either. Make sure you have the right amount of oil in the engine. I believe you are to check the oil in the view window with the bike sitting upright, not on the side stand. If you filled it up leaning on the side stand you have too much oil and it is blowing into the air box. If the oil in the carb mouth is gooey sticky it is from the filter if it is dark and slippery, but not sticky it is crank case oil See if you overfilled the crank case.
I changed the oil on the bike had the oil level about 3/4 within the two lines.
I think the bike noise is spark knock. I watched a video and it sounds about the same... it also happens on up hill climbs under heavy load...
not sure how to fix it though, I always use 91 octane and pretty sure the cam timing is adjusted properly.
Old Feb 20, 2018 | 09:01 PM
Fix it by downshifting. You are running too low of rpm if you are getting knock when under load. THat engine doesn't start putting out decent power without lugging until around 5000 rpm, lighter load maybe 4000. I run a stock 250 with the MCM, jstted with 87 octane and have never heard any detonation or pinging. But I don't run the engine like it is a tractor. I let it sing.
Old Feb 21, 2018 | 12:13 AM
Klxster's Avatar
You don't really have to use 32:1 , the KLX will run just fine on less oil - 50:1 is ok..
Old Feb 21, 2018 | 03:14 PM
canklx's Avatar
Originally Posted by klxster
you don't really have to use 32:1 , the klx will run just fine on less oil - 50:1 is ok..
...lol!
Old Feb 21, 2018 | 03:17 PM
peabrain's Avatar
that is just the air filter
Old Feb 22, 2018 | 02:45 AM
horror_fan's Avatar
No its not the rpm ... ill quick shift to 3 while driving into a hill 3 and ill have it at like 5-6k rpm.
I always run 91.
idk for once .. I haven't ridden the bike the tires are bald and I'm waiting for new ones to arrive.
I just went with cheap shinko 705 for now.
Old Feb 22, 2018 | 11:00 PM
bgcameron's Avatar
Hey horror-fan, I've heard a noise similar to the one in the video you posted. It turned out to be the little black fender in front of the rear tire. It sometimes rattles against the swingarm with the suspension compressed, which I could see happening under load and going up a hill.
Old Feb 23, 2018 | 04:26 AM
horror_fan's Avatar
I totally forgot about that thing.
The first week I bought the bike (like 5 months ago) .. I was investigating a different noise and tried removing that fender but didn't help.
I'll try it again. thanks
jhoffy22
Mar 31, 2012 03:45 AM
deej
Oct 13, 2008 02:27 PM
markmeinteil
Jul 20, 2008 06:42 PM
cleanzx10
Ninja ZX-10R
Apr 30, 2007 05:24 PM
YYY.GUY
Joke section!
Feb 3, 2007 07:25 AM
