Suddenly no power when ignition turned on - Help
Old Nov 14, 2020 | 05:14 PM
BKLR650's Avatar
Default Suddenly no power when ignition turned on - Help
2007 KLX250S with about 5k miles on it. Started and ran fine 2 days ago.
When parked, the AGM battery is typically on a Battery Tender charger.
Today I went to start it and, when turning on the ignition, I get no electrical power to anything.
With the key off, multi-tester shows 12.51V when connected to the battery.
With the key on, multi-tester shows 0.4V when connected to the battery.
I don't have an accurate owners manual, so where is the fuse box?
Next step is to confirm a good, clean ground to the frame.
After that, where should I start testing circuits and tracing wires?
Old Nov 14, 2020 | 08:35 PM
BKLR650's Avatar
Update: Found main fuses (under seat, in front of rear fender, inside a black hinged plastic box), both are good.
Old Nov 15, 2020 | 01:19 PM
durielk's Avatar
U need a new battery.
Old Nov 15, 2020 | 09:02 PM
First how old is the battery, and did you check both cable connections for looseness and/or corrosion?
Old Nov 16, 2020 | 02:35 AM
BKLR650's Avatar
All of my connections were clean and tight, I check things like that regularly.
Hooked up my Schumacher charger / starter to it, seems to be the battery. It's a 2-year old Duralast Gold AGM (from Auto Zone), and it died very suddenly with absolutely no signs of weakness.
Local stores didn't have the right one, ordered a new AGM battery (with better warranty and lower price anyway), scheduled to arrive Friday.
visser
May 1, 2013 03:29 AM
r8d8ter
Aug 31, 2011 03:07 AM
09klx
Jun 28, 2010 08:37 PM
tenacioust
Aug 8, 2009 09:09 PM
Babs
Apr 19, 2006 09:52 PM
