No power?
Old Jun 28, 2010 | 06:27 AM
09klx's Avatar
Default No power?
I rode my bike around the block and when i got home i turned it off. A minute later i turned it on and NO POWER . Nothing turns on!
Battery dead after a year?
Is it the battery or electrical problem?
Old Jun 28, 2010 | 07:28 AM
WestOzKLX's Avatar
Old Jun 28, 2010 | 08:23 AM
slippery750's Avatar
Take off your seat and check your fuses.
Old Jun 28, 2010 | 11:02 AM
09klx's Avatar
All fuses are good(fan & ignition). Fuse next to the battery is good too.
Old Jun 28, 2010 | 11:11 AM
Miaugi's Avatar
Battery might need a charge but is not necessarily finished, put a charger on it and see what happens.
Old Jun 28, 2010 | 12:09 PM
PSUdude85's Avatar
Take out your trusty fluke and with a few simple voltage measurements you should be able to identify if you have voltage from the battery and to the ignition switch or if your battery no worky. I would think you might have a loose connection or something
Old Jun 28, 2010 | 02:54 PM
Check the battery connections first.
Old Jun 28, 2010 | 02:57 PM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
if the fuses are good sounds like a broken wire or disconnected harness situation if it's not the already mentioned loose battery deal.
Old Jun 28, 2010 | 08:37 PM
09klx's Avatar
Battery connected properly.
tyguy81
Aug 9, 2005 03:48 PM
clickhere
Jun 30, 2005 12:03 AM
Chantel
Jun 18, 2005 06:46 AM
ntence
Apr 16, 2005 03:03 AM
onewheel
Feb 3, 2005 04:08 AM
