Rear Brake Light Harness - Connector or NO?
Old May 4, 2016 | 01:12 AM
khibbs's Avatar
Default Rear Brake Light Harness - Connector or NO?
I found what I think is a great product since I ride my 2009 KLXSF 99% on the street for (hopefully) alerting drivers behind me that I'm slowing down... either with brakes or by downshifting
Check out the GearBrake product here
They sell it as a plug-and-play device that you plug into your brake light connector which is usually found under your seat.
So on to my question..... I've followed the wires from the rear brake light to fine where there might be a plug before it hits the main harness and I can't find one. The wires go right into the harness.
Am I missing something or do these wires just go directly into the harness and my only option would be to test out then splice this device in?
Old May 4, 2016 | 02:26 AM
RageHardIntoTheBendies's Avatar
There is a plug at the light end?
Old May 4, 2016 | 03:01 AM
MaximusPrime's Avatar
The plug (as long as the taillight is stock) is under the tail piece farther back.
Old May 4, 2016 | 03:04 AM
The tail unbolts from the underside IIRC.
Old May 4, 2016 | 12:25 PM
khibbs's Avatar
Max, Thanks for the reply and I'll use the bolts underneath to remove the light assembly and check. The plug must be right before the light if that is the case.
I'll check and post up the results..thanks
Old May 4, 2016 | 04:19 PM
durielk's Avatar
Just splice it under the fender, it is only 1 foot away.
Old May 4, 2016 | 07:30 PM
The bolts undo the tail piece which will reveal the wiring plug.
Old May 5, 2016 | 12:31 PM
khibbs's Avatar
Yep...you guys were right. Unbolted the light housing and the plug is only about 5" from the light itself. Thanks for the guidance. It looks like splicing the unit under the seat will work best.
BP88
Feb 25, 2010 02:37 PM
kory_martin25
Jun 26, 2009 09:35 PM
WestCoast4Life
May 4, 2008 09:47 PM
Crasher986
Jul 8, 2007 10:07 PM
