Rear Brake Light Harness - Connector or NO?
2 Attachment(s)
I found what I think is a great product since I ride my 2009 KLXSF 99% on the street for (hopefully) alerting drivers behind me that I'm slowing down... either with brakes or by downshifting
Check out the GearBrake product here They sell it as a plug-and-play device that you plug into your brake light connector which is usually found under your seat. So on to my question..... I've followed the wires from the rear brake light to fine where there might be a plug before it hits the main harness and I can't find one. The wires go right into the harness. Am I missing something or do these wires just go directly into the harness and my only option would be to test out then splice this device in? Attachment 8438 Attachment 8439 |
There is a plug at the light end?
The plug (as long as the taillight is stock) is under the tail piece farther back.
The tail unbolts from the underside IIRC.
Max, Thanks for the reply and I'll use the bolts underneath to remove the light assembly and check. The plug must be right before the light if that is the case.
I'll check and post up the results..thanks |
Just splice it under the fender, it is only 1 foot away.
The bolts undo the tail piece which will reveal the wiring plug.
1 Attachment(s)
Yep...you guys were right. Unbolted the light housing and the plug is only about 5" from the light itself. Thanks for the guidance. It looks like splicing the unit under the seat will work best.
Attachment 8429 |
