Rear brake ergonomics w mx boots
Old Apr 10, 2015 | 01:59 AM
Originally Posted by Zeno
My '06 didn't come with any rubber inserts, but I put on wider IMS pegs anyways for more foot support.
Yeah, I was thinking maybe I could put some sort of rubber covers or something to increase height of pegs instead... but I like them at the height they are now and don't want to compromise the metal spiky grip the pegs currently have for when I get bike and myself covered in mud.
EDIT - I do just want to try TNC's method though.... once it's in the vise, what do I use to actually apply pressure and bend it? I feel like it still may be hard for me to get enough leverage on it.
The pad end of the brake pedal isn't that large, so I just used an old fork tube for leverage. I extended the tube down to the point about where I wanted the small bend to start. Probably any decent length of pipe that will fit over the foot pad will do.
Old Apr 10, 2015 | 02:05 AM
MaximusPrime's Avatar
Heat will help the bending process.
Old Apr 10, 2015 | 03:03 AM
Zeno's Avatar
Excellent! Thanks guys.
I do have a heat gun with a high setting that may help bending process. Now I just need big screws to secure my vice on my work bench, and a pipe of some kind to apply leverage.
Old Apr 10, 2015 | 03:12 AM
RockabillSlapMatt's Avatar
Get a metal pipe and put it on the end of it to increase leverage and slowly pry down and measure the distance.
Old Apr 15, 2015 | 04:40 PM
Tacoma660's Avatar
I have no problems with the brake it up shifting thats giving me problems
Old Apr 15, 2015 | 04:59 PM
Yes, same problem over on the shifter side for those with bigger feet and/or MX boot clearance for some...even with changing the spine orientation. For many the shifter is too short. Many of us have gone to the Honda XR650L shifter that you can tweak a tiny bit to clear the generator case. Got mine from MSR...inexpensive. So much better for a lot of us.
Old Apr 15, 2015 | 07:21 PM
Tacoma660's Avatar
I was hoping to move the shifter up to wear my boots to the snirt run on tug hill this saturday but it looks like ima have to order a longer shifter and wear my rubber boots for now.
Old Apr 15, 2015 | 07:57 PM
If you're creative, you can cut and weld in an extension on your existing shifter to make it longer.
Old Apr 15, 2015 | 09:19 PM
ol'klx-er's Avatar
Or can get the welder where you work to do it.
Old Apr 16, 2015 | 01:03 AM
Scott...you cheap basstid!
TexasFlyer
May 26, 2011 03:02 PM
dan888
Nov 19, 2008 11:59 PM
ntloser
Oct 23, 2006 02:07 PM
espacef1fan
Sep 4, 2006 06:55 PM
Kawacon
Aug 30, 2006 09:27 AM
