New Tires
Old Jun 29, 2012 | 02:38 PM
Websurfing101's Avatar
Default New Tires
I just put on a set of new Shinko 244 tires on the KLX 250s. The front tire is 3.00-21 and the rear is 5.10-18. I have not had a chance to really try them out yet. Since I went with a larger rear tire, what can I expect in regards handling and performance on and offroad? The rear tire looks a lot beefer than the stock tire and seems to have added some ride height.
Old Jun 29, 2012 | 03:01 PM
There will be variables on what you can expect on a bigger rear tire. Acceleration on a KLX will be a bit more sluggish. RPM will drop a little bit as compared to speed. Steering could be a little quicker with the small increase in ride height at the back. Turning the bike into a corner at the initial movement, however, might actually be a bit slower or more sluggish. Some of this could be affected more or less by the tread pattern. You might get a benefit in mud or sand. These are the main issues that come to mind.
Old Jun 29, 2012 | 03:11 PM
I tend to ride in areas with a lot of sand and I am tired of digging holes. I guess that I will try the tire for a bit and if it does not workout, then I will go with the 4.60-18. The Shinko tires are really priced cheap enough.
Old Jun 29, 2012 | 03:41 PM
jeffzx9's Avatar
(Shinko's have a Yokohama pedigree. A lot of tire for the money.)
Old Jun 30, 2012 | 03:26 AM
toyotabuilder's Avatar
i have run tons of tires on mine and by far the two best dot's for a lot of dirt are the pirelli or the Michelin ac10 but that's a tire that suits how i ride. if you are in the sand and can keep moving these work well(NOT DOT)Kenda K775 Parker Desert Terrain Rear Tire - Dirt Bike Motocross - Motorcycle Superstore
or these too http://www.maxxis.com/MotorcycleATV/...s-SM-Rear.aspx
olderthandirt
May 3, 2009 07:17 PM
Roadrage
Ninja ZX-10R
Apr 9, 2008 07:55 PM
DeFran
15
Jun 5, 2007 12:32 PM
calamarichris
Ninja 500R
22
Oct 1, 2006 03:39 AM
markmeinteil
Sep 14, 2006 04:46 PM
