KLX250 EFi Main Throttle Sensor FI-Error-11
Old 01-18-2015, 03:43 PM
Nuvorigo_uk's Avatar
Unhappy KLX250 EFi Main Throttle Sensor FI-Error-11
Seems I have error code 11, confirmed with oscilloscope and the Main Throttle Sensor is dead. Seems I can't get this as its not listed anywhere is this the case?
The manual says replace the whole throttle body assembly, yikes! It’s only a sealed up variable resistor, I could pull it apart, but that would probably wreck it. Does anyone know where else these sensors are used and can be bought?
Thanks.
Old 01-19-2015, 04:54 AM
JoelThailand's Avatar
Yep your correct the Throttle body comes as a complete unit. I had an issue with my Sub Throttle sensor a while back & inquired on the price here in Thailand new from Kawasaki to save me bothering fixing it & it was 10,000 Baht (200 pounds). Yikes!!
That prompted me to get down n dirty with a mechanic friend & found it was just the shaft running from the servo motor to the sensor was out of alignment & fixed in a few hours...Phew!!
Old 01-31-2015, 04:16 PM
Yep, got it sorted found a throttle sensor (variable resistor) on ebay advertised as for a 250R EX250. Tested and the correct resistance was measured, fitted and working fine, phew!
Tezh58
07-15-2019 10:14 AM
redmonster
01-28-2011 07:45 PM
drpepper
01-06-2009 06:02 AM
eas
02-21-2008 12:36 AM
robdandrea
02-04-2007 08:21 PM
Quick Reply: KLX250 EFi Main Throttle Sensor FI-Error-11
