KLX250 EFi Main Throttle Sensor FI-Error-11
Seems I have error code 11, confirmed with oscilloscope and the Main Throttle Sensor is dead. Seems I can't get this as its not listed anywhere is this the case?
The manual says replace the whole throttle body assembly, yikes! It’s only a sealed up variable resistor, I could pull it apart, but that would probably wreck it. Does anyone know where else these sensors are used and can be bought? Thanks. |
Yep your correct the Throttle body comes as a complete unit. I had an issue with my Sub Throttle sensor a while back & inquired on the price here in Thailand new from Kawasaki to save me bothering fixing it & it was 10,000 Baht (200 pounds). Yikes!!
That prompted me to get down n dirty with a mechanic friend & found it was just the shaft running from the servo motor to the sensor was out of alignment & fixed in a few hours...Phew!! |
Yep, got it sorted found a throttle sensor (variable resistor) on ebay advertised as for a 250R EX250. Tested and the correct resistance was measured, fitted and working fine, phew!
