Klx 250/300 engine questions,
Old May 25, 2017 | 07:45 PM
motomarauder's Avatar
Originally Posted by TNC
#4--I took from your first question that you already have a good, serviceable 331 kit. If so, it wouldn't be worth what is likely an imperceptible difference between a good 331 kit and a 351 kit. If you don't actually already possess a 331 kit, well, I'd probably go 351.
#5--I think I'd pass on using that carb unless you get some really clear direction from Yosh on how to jet it for the KLX...and the jets to do the job.
#6--Yes, sounds like the cam chain guides. That's not a common failure in such a catastrophic manner. You're going to have to break that engine down to splitting the cases IMO to insure what you're dealing with. The crank may need some professional inspection.
#7--The KLX drivetrain and cooling system are more than adequate to handle any big bore kit we've dealt with here. If abused, the clutch might be weakest link but not to any concerning degree.
Clarification: I'm taking it that the 300 head you have is complete and in good order, and the head that had valve/piston contact is the original 250 head???
the head in there now is the original. I was told that the 300 head will fit no problems so I am looking for a 300 or 250, whichever I can find.
Old May 26, 2017 | 02:51 AM
GBAUTO's Avatar
Guaranteed that the engine was run low on oil-although the bottom end and trans use ball bearings I would look for another motor to rebuild. I can tell you from experience that it doesn't take much to get a rod knock. Any pics of the carb?
Old May 26, 2017 | 03:43 AM
Anyway of diagnosing the rod and crank to see if the bottom end is still good?
[IMG][/IMG]
Old May 26, 2017 | 04:02 AM
Also here are some pics of the bike, head, cylinder, and piston.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Mike Fournier
Mar 2, 2015 05:36 AM
valvedropper
May 7, 2013 09:07 PM
drawjim
May 11, 2012 04:25 PM
DirtSurfer
Feb 17, 2007 05:09 AM
Bad Bear
Jul 24, 2006 12:59 AM
